Question about Vacuums
Assembly I am trying to assemble the eureka smart boss. The problem that I am having is that the handle is not completely fitting into the cleaner body. I can slide the handle into the handle supports but it doesn't seem to click together. There is a space at the top; it doesn't seem to be able to fit as closely as the bottom. Thanks, Lisa
    President:
  • 1,673 Answers
It may not just slide into place, you may have to knocj it into place, then put the screws in to secure it.
Posted on Mar 25, 2008
SOURCE:
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
What filters do I use for this? does the Hf-9 work?
Hey, this is Jeremy with Crucial Vacuum,
Unfortunately, you did not include what kinda of vacuum you were trying to make sure the Eureka HF-9 filter was compatible with. Below I have compiled a list of all of the models that the HF-9 filter will work with for you.
  • Fits Eureka Upright Style HF9 Victory & Whirlwind Vacuums.
  • Eureka Victory - 4300, 4400 & 4600
  • Eureka Victory Enviro Vac - 4370, 4377, & 4470
  • Eureka Self Propelled - 5184, 5185, 5187, 5188, 5190, 5191, & 5196
  • Eureka Whirlwind - 4180, 4380, 4381, 4480, 4481, 4483, 4488, 4489, 4580, 4686, & 4689
  • Eureka The Boss - 4672
  • Eureka Smart Vac - 4469, 4473, & 4476 & Sanitaire- S4170, SC4570, & SC4580 models.
You can purchase replacement parts for Eureka (including the HF-9 filter) direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 12, 2015 | Vacuums
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Eureka Smart 4870DT Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a eureka the boss smart vac petlover vacuum and I cannot find the book on how to replace the belt. I have opened it up, but there is a silver roller that is confusing me.
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
Oct 10, 2009 | Vacuums
Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Oct 02, 2009 | Vacuums
Eureka Boss Smart Vac 4870 evidentally overheated. Allowed unit to cool and observed a spark/smoke at outlet when it was replugged into the power outlet. Unit will not power up now. Circuit breakers in...
The wires leading to the switch inside my Eureka 4870 are fried...black and melted. Don't know why that happened, but it may be what is happening to the others listed on this site as well.
Dec 18, 2008 | Vacuums
Eureka the Boss Smart Vac. Hose has suction, but still isn't picking up. Weird.
Your belt is probably broken. Check your belt and make sure your brushroll has not seized. If both of those check out ok, (because the smartvac belt doesn't stretch,) the belt tensioner assembly may have gone bad.
-R
Aug 11, 2008 | Eureka Vacuums
Euerka Smart Boss upright
Price of Belt: $ 7.49 from www3.sears.com
Part No. 61110A
Price of Bag: $7.99 for a pack of 3.
Part No. 61115A or Eureka Bag Type RR
Estimated Repair Cost: $75-90 pending parts and labor rates
The likely possibility is that the belt was installed wrong. Without seeing the unit myself, I cannot say if the pulleys are mis-aligned. I will get back to you if I find any new information.
Mar 14, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuums Logo
90 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
