Question about Hitachi 51F59 51" HDTV Projection Television
Big red circle in the middle of the picture
Picture is progressively getting worse. dark scenes are barely visible. red circle shows up strong when scene on tv is in a darkened room. color is getting worse. we replaced lamp but red circle is still there and now everybody looks yellow. color cannot be adjusted to make the tv look good.
  • 1,476 Answers
Your light engine is bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 30, 2010
Testimonial: "Thank you so much for the rapid response and detailed information. We really appreciate it and will let you know the end results!"
How to fix the big dark circle in the middle of the screen
I think you may be having a problem with the projection bulb.
Jun 09, 2014 | Sony VPL-ES1 Multimedia Projector
The instrument dial needles in my Cefiro have become very hard to see. They're dark red and thin and just don't show up (day or night). This has become progressively worse over the years. Is there a way...
If you can get the Perspex face off the dash panel and you use a very fine paint brush you may be able to paint the pointers with a anti collision orange paint > this tends to reflect any light and would be visible with dash lights on. IF you cannot get to the pointers easily then a replacement dash unit may be the answer.
Feb 15, 2014 | 1994 Nissan Cefiro
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are...
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Nov 13, 2010 | Philips 55PW9363 55" Rear Projection...
My TV picture seems to have a "sheen" aking the
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Red rash that shows through in dark scenes. Can't
Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
Dec 20, 2009 | Toshiba 50HP66 50 in. Plasma Television
Pt47wx49 panasonic rear projection tv has very dark tv scenes
Has this problem been getting progressively worse? I would suggest cleaning the CRT's inside the tv with lcd screen cleaner or something similar. Make sure the tv is unplugged, all you have to do is undo some screws on the back to gain access to the inside of the cabinet. Hopefully that's all it is. Your set has no lamp if it is a Panasonic Pt47wx49.
Nov 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red cirle in the center of my screen durning dark scenes
This sounds like the light engine has gone bad or has dust/dirt in the light tunnel or DMD assembly. The light engine would have to be removed to check for dirt. If the engine is bad it can cost over $800 just for the engine not including shop charge. Unit would need to be taken to a repair shop to find out what is actually causing the problem.
Sep 06, 2009 | Samsung DLP HL-P5663W 56" TV
I have a JVC tv only 1 year old and the picture is getting dark.
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
Dark circle in middle of picture
I had the same problem too! When zoomed in, those spots become very visible. I try hitting it off but it's still there.. can anyone help us???
Feb 08, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Hitachi 51F59 51" HDTV Projection Television Logo
221 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
