I have windows 7 installed on my laptop .. can I install also windows Xp ... then i can choose when the computer startup between operating system Xp or 7 ???
  • naddoura Apr 30, 2010
    i will try thanks for sharing the informations
  • 666 Answers
Yeah what you want to do is during the installation process it will ask you for a partition what you need to do is partition an amount of space away for the new operating system to run on when it asks if you would like to create a new partition
hope this helps
Robb
Posted on Apr 30, 2010
Windows xp startup problem
You may need to "wipe" or reformat your entire C drive to be able to install Windows program again. I would suggest installing WIN7 program as WIN XP is at its end of life cycle for that operating system and Microsoft may not support it any longer.
If possible try installing WIN7 once again, and if requested to reformat or do an entire install, choose YES.
WIN 7 should then reformat your C drive, erase everything that is on it and then install as WIN7 program.
Be sure you have your program license key to install WIN7.
Mar 31, 2014 | Dell Inspiron 6400 Notebook
I need to find a set up disc
What operating system set up disc are you referring to ?
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
Toshiba laptop restarting
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
or
Oct 23, 2012 | Toshiba Satellite M35X-S311 Notebook
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
or
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
bootrec.exe /fixmbr
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
hope this helps
Aug 09, 2012 | Computers & Internet
Sir, i am using windows 7 ultimate. i would like to install another one operating system (i.e) windows xp professional. now i insert the win xp professional disk into it but the install windows xp is...
boot your computer with windows XP cd. it will install winXP automatically but remember to install windows XP other than the drive where your win7 is. for examp: if your win7 is in C drive, install XP in D drive. hope you can do.
Aug 29, 2011 | Computers & Internet
My son accidently shut his laptop down whilst installing microsoft office and now he has an error on startup: status: oxcoooooe9. I tried rebooting and starting in safe mode but it always goes back to...
Instead of re-installing the Operating System you can do an Operating System repair. Boot to the Windows Operating System installer disc,. If you have XP, boot to the XP installer disc then enter the setup program. There will be an option that says "Press R to Repair Computer". Press letter R then let the setup finish. For Vista/7, boot to the installed disc then select "Startup Repair" This will repair all corrupted Windows file and will keep your data intact,
Hope this help.
Mar 26, 2011 | Toshiba Satellite L305-S5908 Notebook
Toshiba satellite L300 will not boot up. error code 0xc00000e9
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
Mar 07, 2011 | Computers & Internet
Cannot load drivers
there isnt such thing as impossibility to load and install drivers..if the system refuses the drivers you try ..this means that they are not the one you need to install ...Even if the drivers came on a disk with the laptop ...if you changed the operation system ..or the the bit of the system ..you need another set of drivers..
To be more clear for example if you installed windows 7 and use to have vista ..you need drivers for windows 7 ...even if some of them for common devices may fit from vista 32 to windows 7 32..Or ...if you downgraded from Vista to windows XP..you need drivers for xp ..and the other way around...The only way the drivers you have will fit after re-installation if you have the exact same operating system reinstalled..
So..this will be the site where you should download the drivers for you operating system..
http://www.acersupport.com/drivers_download.aspx
so ...choose the model ...notebook ...aspire/4520..after that choose from the 3 main windows ..xp .....vista ..or windows 7 ..and download all of them one by one ..and install ..
May 12, 2010 | Acer Aspire 4520-5582 Notebook
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
I have a Dell Inspiron Laptop Having Issues
You need to not delete the partion but you need to do a format on your HD (harddrive) to basically remove EVERYTHING. What you did was just installed a second windows onto your computer.
Feb 04, 2009 | Dell Inspiron 8200 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
