Question about iRobot Roomba 560 Robotic Vacuum
My Roomba only works correctly when I leave out the rubbery type brush (not the fiber filled brush)...... when I leave the rubber one in, it doesn't pick up & then finally stops & says REMOVED BRUSHES..... I have cleaned every nook & cranny of this thing... inside & out. I finally found that if this one brush is left off.... it works great & has for 2 weeks??? What could be the problem?
    Brigadier General:
  • 3,917 Answers
First let’s try one more time to clear out anything that might be caught inside. For this disassemble the green brush cage unit, partially, from the blue box. This would expose the cover of the gear box. On the left side, with the white nylon holes in which the square ends of the brushes plug. Remove the cover of the gear box with a tiny Philips screw driver might be there are 6 screws. Inside you would see two Golden Retrievers. Once, cleaned meticulously, the Roomba will be back. If this does not resolve the issue then probably needs this part
http://www.totalvac.com/accessory/parts/82701.html
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 30, 2010
Roomba does not fill upper tray.
brushes are not turning, you can see this if you remove dust bin and start the roomba, remove brushes clean thoroughly removing yellow end pieces as well to remove trapped hair, re inbstall brushes and turn manually about 20 turns and re try cleaning, try this a couple of times
Jul 06, 2010 | iRobot Roomba 530 Robotic Vacuum
Roomba 530 makes a thumping noise every secondand stops with a message to clean he brushes. I have cleaned the brushes and filter but to no availe the thumping continues.
You also need to pull off the yellow bearings from the end of the brushes (one on the brush one and one on the rubber one) and remove hair from the axle there.
May 20, 2010 | iRobot Roomba 560 Robotic Vacuum
Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Makes a clicking noise and stops after about 5 minutes
Ladies and gents,
I can't bear you moaning like this honestly! Here is the solution-
get your self a tiny 4 headed (philips screw driver) and test your ROOMBA
1) REMOVE THE RUBBER BRUSH AND RUN ROOMBA ON JUST THE BIG BRUSH
2) CHECK IF ROOMBA STARTES CLICKING AND ODES THE SAME THING
3) IF NOT PUT THE RUBBER BRUSH BACK AND REMOVE THE BIG BRUSH AND THEN CHECK IF CLICKING CONTINUES.
4) ONE OF THEM WILL BE THE CULPRIT. REMOVE THAT BRUSH AND YOU WILL SEE TWO 4 HEADED(PHILLIPS) SCREWS ON EACH END OF THE OFFENDING BRUSH- LOOSEN THE SCREW AND YOU SHOULD SEE LOADS OF HAIR AND FIBER ROUND THE BEARING.
5)TAKE THE BEARING OUT AND REMOVE ALL THIS HAIR-YOU WILL BE SURPRISED HOW MUCH THERE IS
6) PUT THINGS BACK TOGETHER AND ROOMBA WILL RUN LIKE NEW
i PROMISE!
Nov 27, 2008 | Vacuums
Roomba 500
Roomba 500 Series have a serious problem with hair and other fibers working their way into the drive gears. The resulting resistance in the drivetrain is interpreted by the machine as overloaded brushes. People who experience this problem should complain to iRobot technical support. If the machine was purchase less than a year ago, they should ship a replacement assembly to you at no charge.
Oct 17, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
Roomba Discovery
The plastic gears that drive the sweep brushes strip out easily on these. You can get the company to repair it for you but they make it a big hassle. I opted to buy the gear set on EBAY and replace them myself.
Dec 04, 2007 | Roomba Robotic Floor Bagless Vacuum
Roomba turning off after 30 sec.
I was having the same problem. Roomba would run for 30 seconds and then stop. I tried everything -- then I took the small rubber brush out and removed the small nut at the end. It was packed with dust to the point that it could not turn easily. I cleaned it out and now it is working like a champ. I think the automatic shut down was just a sign that there was too much strain to turn the brushes.
Nov 27, 2007 | Roomba Robotic Floor Bagless Vacuum
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
152 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
