What is the difference between the Lexmark 100 and the 100A Printer Cartridge for the Lexmark pro 705? Is it just the number of pages they will print or is the 100A able to be refilled?
  • ddbusiness Apr 30, 2010
    Is the 100A available in Australia? I have not seen it yet.
    President:
  • 524 Answers
The regular version (#100) is not refillable. It is the "Return Program" or "Prebate" cartridge. Supposedly, when you buy this cartridge you agree to return the empty cartridge to Lexmark. In return, Lexmark gives you roughly $5 off the retail list price of the cartridge.
The "A" version (#100A) can easily be refilled. However, the price of the cartridge is roughly $5 higher than the regular version, so most people unknowingly buy the regular version. So it's really depends on you if you want to refill your cartridge you should buy 100A
Please let me know if you have any further questions or concerns.
Thanks.
Posted on Apr 30, 2010
Testimonial: "Quick response and very helpful"
Is it true that both my new Lexmark Prevail Pro 705 print heads quit printing in color is because I didn't use Lexmark OEM ink cartridges?
Some Lexmark cartridges have an RF chip mounted underneath the label on top. Most of these are set to self destruct on first use to prevent refilling. You probably need to risk the cost of a new cartridge to find out if it is a cartridge problem or a printer problem. Unfortunately you should not take out a cartridge or replace one while the machine is powered. The system also frequently registers an serial number on the cartridge and stores it to prevent "hot swapping" cartridges
Dec 11, 2017 | Lexmark Prevail Pro705 Wireless AIO...
Lexmark privail 705 traag printen lexmark pro 705 voor windows 7 k64
could be the document size or not enough memory or if you are printing from a network could be network traffic... try deleating the current driver software and reinstall the new software using the disc that came with the printer
May 03, 2014 | Lexmark Prevail Pro705 Wireless All-In-One...
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark pro 705 prints vertical lines
The firmware update addresses a number of known issues for your model including print quality problems. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.
Should the problem continue, it could be that your printhead is affected with the printhead problem, please contact Lexmark Technical Support Center to further diagnose the problem. If needed, they can replace the printhead for you for free.
Oct 19, 2011 | Lexmark Wireless All-in-1 Color...
My Lexmark prevail pro 705 has stopped printing anything colour even after i have replaced all the cartridges??
This article on How to Troubleshoot the Vizix Ink Technology will help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
Jan 11, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
How to change lexmark Cartridge
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
I installed an old Lexmark Z 705 and I think it has plenty of ink but it is barely printing. Is there anyway to rejuvenate the cartridge of clean the contacts if it is just "dried out?
GO TO LEXMARK.COM/SUPPORT PAGE, MAKE SURE TO WRITE DOWN THE SERIAL NUMBER OF YOUR UNIT TO FIND ITS USER GUIDE, THE SITE SHOULD HAVE A PDF. VERSION OF THE USERS-GUIDE FOR THAT PRINTER, CLEANING INSTRUCTIONS FOR THE HEAD SHOULD BE THERE...JON T
Dec 07, 2008 | Office Equipment & Supplies
1,095 people viewed this question
k24674
jasbo
jasbo
