Question about HP Photosmart C4280 All-in-One InkJet Printer
Not reading the ink cartridges
I have removed the cartridges and reinstalled, i tried new cartridges, it still tells me that the carttidges are missing or undetected
    Scholar:
  • 166 Answers
It tells me the cartridges are empty, then when i open the lid it says no cartridge! its not been used for a few months, and i refill them with generic refills...any thoughts? tried the switch off and on -...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Make sure that your ink cartridges are full and that they are genuine brother inks; refills or generic ink cartridges are not guaranteed to work properly.
Thanks,
Pat
Mar 29, 2010 | Brother MFC-620CN All-In-One InkJet...
Replace yellow ink but machine says no cartridge
When you get the "no cartridge" message it's because one of the sensors does not recognize ink in one of the cartridges.
First open the ink cover and read the LCD screen.
The LCD will tell you which cartridge is having a problem. You should change which ever cartridge is telling you there is a problem.
If the LCD says there is a problem witht he yellow (which you just changed) then follow the below steps.
1. Unplug the power to the printer.
2. Remove all 4 ink cartridges.
3. Close the ink cover with all the inks removed.
4. Plug the power back in.
5. When the LCD says "ink empty" you will reinstall all 4 ink cartridges.
Thank you,
Mar 29, 2010 | Brother MultiFunction Center MFC-440CN...
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
New cartridge fitted still reads low ink.lexmark x3480
Try this... Unplug the printer from power and restore power... also, reboot the computer. if that doesn't work, try reinstalling the cartridge or reinstalling the software. If there is an option to ignore these messages, it will be in the options srction of your printer manager program.
Dec 29, 2009 | Lexmark X3480 All-In-One Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
New ink cartridge installed, message on printer reads ink cartridge missing or not detected
Hi my name is Eric,
I can help you with your issue ,
If using non oem ink the ink level switch may be bad or not connected,
Remove and reinstall or try another cartridge
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 07, 2009 | HP Office Equipment & Supplies
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
H P psc 2210 printer will not accept ink cartridges have used from this supplier in the past with no problems display reads "remove and check cartridge" this I have done but no cure.
Are you using cartridges that have been refilled? If so I would go buy brand new HP ink cartridges or I would find known working but used cartridges and try again. The ink cartridges on any inkjet type printer are not made to be refilled and if you were to call HP about this problem they would tell you to replace the ink cartridges with new ones and try again.
Nov 10, 2008 | Computers & Internet
No ink display on brother mfc240c
First make sure that you are using Brother Cartridges, their machines are very sensitive to using generic ink. Put a brand new set of ink in the machine. Pull all the old cartridges out and put all new cartridges in. If this does not resolve the issue contact Brother, they are very good about helping their customers.
Jan 02, 2008 | Brother Multi-Function Center MFC-240C...
HP Photosmart C4280 All-in-One InkJet Printer Logo
138 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
