Question about LaCie Computers & Internet
When the drive turns on, it makes noise and the lights come on, and it is obviously functional. The computer makes noise to indicate a USB device has been plugged in, but the drive will not register, either in autoplay, or in My Computer.
  • 4,281 Answers
First make sure your usb cable is fine .Try in different usb ports of computer.
Then press windows key + R key so you can see run type in run "devmgmt.msc" then press ok then you can see device manager then uninstall all usb drivers then it automatic install.
then check.
If still same issue then type in run "regedit" then press ok then you can see registry editor.
Then locate following keys.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
Then select it then you can see in right pane upper filter and lower filter.Delete both upper filter and lower filter.
Then restart computer then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Apr 30, 2010
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
My WD 1TB my passport external hdd doesnt show up in my devices but the light is on and it makes a weird whirring sound, can this be fixed
You can download a program from WD called Data lifeguard Diagnostic for windows there is a floppy and a windows program. I made a bootable floppy and started my computer with the floppy and typed windlg.exe and followed the instructions...http://wdc.custhelp.com/app/answers/detail/a_id/1329/~/how-to-create-a-data-lifeguard-diagnostics-bootable-cd
Jan 01, 2013 | Computers & Internet
Plug in cord and just hear clicking noise not connecting to a computer
This means that the WD could is trying to connect to the computer but looses the connection. Try plugging the usb cord in another usb slot on your computer. Or try using another cable. Make sure the WD is not giving out any red led light on the device.
Mar 01, 2011 | Western Digital My Passport Essential...
When i format it only 1 meg formats and the system says everything is OK I cannot get it to format to the full size
USB devices least require formating once acquire from retail. Ascertain that the devcie is compartible to the computer that is requesting resourcefulness. For example, in a situation that computer displays messages either requiring complementary codes resources to attain functionality is indication of system outdate. Ascertain each devices compartibility. For example, recent computers are innovative already compartible to USB devices. Depending on the request from the device would require adjusting features on the computer. For example, USB device assume functionality soon after being pluged into computer. However the type of files documents that require communcations with device predicts teh sequecne of events. Computers that perform with media files, documents or programs in complicated formats would require modifications to attain functionality with USB device.
Feb 20, 2011 | Memorex 32GB Mini TravelDrive Flash Drive...
My External Hard Drive isn't working anymore, to say the just of it. It's on, lights on(not flashing, it flashes when it's being written to or accessed), usually has a regular clicking noise from it...
When a hard drive makes a clicking noise, this indicates the hard drive has failed and if the BIOS and the Computer Management does not detect it, then this confirm a hard disk failure.
To get the computer operating again, replace the hard disk, then install Windows on the hard disk using the Windows installation CD and the Windows product installation code that is on the label on the computer then install the device drivers and your programs.
Oct 21, 2010 | Samsung Computers & Internet
Indicator light illuminates but PC does not read the thumb drive. have tried pushing down the thumb drive as well as all the different ports on the hard disk.
The issue with the USB drive (assuming the device is working properly) is that Windows will assign it a drive letter, which is probably the E: drive. Since that's already in use it won't show up in "My Computer", but will make the USB noise and act normal otherwise.
To correct this you can manually assign each device their own drive letter (start with the bottom of the alphabet so there are no future conflicts).
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Jan 25, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer won't recognize the store-it drive external hard drive
You may have a problem with your drive or the usb ports so we need to check both. The green light usually just means the device is getting power.
The first thing to do is unplug the drive and reboot the computer. Make sur eit has finished booting up completely. Then plug it into a different usb port NOT the same one. If it detects and works it was just the operating system or motherboard not recognizing whats called a legacy usb device.
Next we want to try a different usb device in the computer to make sure the ports are working.
And we want to try the drive in another computer to make sure it is working.
At this point you will know if the problem is your drive or the port. If it is the drive you can get it runnning again sometimes by taking the actual drive out an dputting it into a new external drive enclosure kit.
Jul 09, 2009 | Pexagon Store-It 80 GB USB Hard Drive
The hitachi 500gb usb 2.0 external hard drive. This drive will not show up on any computer that I plug it into. When i turn it on the red light comes on, but no green. my computer crashed and...
Assuming that you have installed a fresh windows installation after crash, you might not installed the usb drivers.
to make sure that the usb drivers are installed and correct drivers go to controlpanel->system->device manager.
and check in that no yellow icons are present in the usb.
you said that the red light is on. that is power indicator and no data transfer.
green light indicates power and data transfer is on.
check your drivers and try to update or reinstall if the drivers are already present.
CAUTION: before reinstalling or updating see that you uninstall the previous drivers.
Apr 21, 2009 | Computers & Internet
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Computers & Internet Logo
24 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
