Question about HP Compaq WF1907 Monitor
Compaq WF1907 monitor keeps going to sleep every couple minutes..
I've tried dusting out both fans, all cables and ports. I've tried startup repair, system restore & even set the screen saver power off setting to 'never'. Still keeps cutting off every couple minutes which results in me having to reboot several times just to get a picture. Then its only for a few minutes. My computer operates just fine. Sometimes for hours at a time its ok, then the monitor starts again. Please help !!!!
  • 24 Answers
Sounds like the backlight may be on its way out.
Put a large font single word onto the screen in a high contrast such as white on black. Get the monitor near a window if possible, and the next time the monitor seems to go off, see if you can still feintly see the image using natural light.
The backlight can be replaced, but it is somtimes so expensive, it's easier to buy a new monitor.
How old is it?
Posted on Apr 30, 2010
MY MONITOR SHOWS: VGA No signal DVI No signal then shows: Check Video Cable Then: Monitor going to sleep
Try another cable, borrow one, then try monitor in another PC / laptop, if it works then either the software settings for the sleep mode are on or it may be a faulty video card.
Oct 15, 2010 | HP Compaq WF1907 Monitor
Volume control stays on screen
hi,
while the system is turned on,
Remove all cables from monitor.
keep pressing the power button.
reseat the cables.
release the power button.
press the power button again to turn on the monitor.
It must work.
else the monitor needs repair.
Rate this solution and comment to keep in touch or further interaction
Sep 16, 2010 | HP Compaq WF1907 Monitor
WF1907 Monitor is in sleep mode - how can i get it to stay on?
If understand your issue correctly , your system and monitor is fine . The only problem is that the monitor switches off after some time.
If after moving the mouse or taping on the keyboard the monitor comes back . Then we can solve the problem buy adjusting the power settings in the OS .
If the monitor doesn't come back on if you strike the keyboard or click the mouse. Then the problem could be with the monitor.
Depending on the OS you have you can disable sleep by going to the following link
http://www.wikihow.com/Disable-Sleep-Mode
Jun 17, 2010 | HP Compaq WF1907 Monitor
Can't get signal for VGA nor DVI cables... Cables are fine... Monitor is always going to sleep and I can't see anything from PC
if pc boots up your video card is shot you will have 2 replace it this happens alot on hp compaq I dont no why. you might want to check if there has been a recall on the video cards from hp website
Apr 06, 2010 | HP Compaq WF1907 Monitor
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
No image
This monitor series( HP Compaq WF1907) seem to have a inherent problem with the sleep mode control circuit. You should take this unit into the service center for repair. Hope this helps.
Apr 01, 2009 | HP Compaq WF1907 Monitor
Using a Compaq WF1907 monitor with a Playstation3
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
Oct 25, 2008 | HP Compaq WF1907 Monitor
I cant get the monitors resolutin at 1440x900-60Hz and the monitor keeps going to sleep
your graphics card doesnt support the resolution that your monitors native resolution is set at.
btw, what graphics card are you using?
Nov 23, 2007 | HP Compaq WF1907 Monitor
HP Compaq WF1907 Monitor Logo
323 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
