Question about Sony Cyber-shot DSC-H9 Digital Camera
Screen says 'can not change flash settings'
A message on the screen says 'can not change flash settings' & it wont allow me to use the flash at all, what do i do to clear this?? Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 59 Answers
If you need a manual go here
http://www.retrevo.com/search?q=Sony+DSC-H9&rt=oa&modelid=1075104
on page 50 is has a chart showing when the flash is used, or not available. P S A M all make it available, in Scene, or the one with the mini camera, it is not adjustable. If it will not work in PSA or M then it will need to have a tech look at it, Please try changing modes first and let us know if this was your problem.
Posted on Apr 30, 2010
Setting up answering machine for UnidenDECT 6.0
To replace the default greeting with a personal one
( Uniden model D1680 & similar ):
1. press [MENU]
2. scroll to "Ans. Setup" then press [select]
3. scroll to "Record Greeting" then press [select]
4. It will display & tell you aloud to press [select]
5. Speak Clearly your desired greeting, then press [select]
6. press [END] to conclude & exit
Apr 18, 2015 | Uniden DECT 6.0 Cordless Phone
My g.e. model 28111 series dect 6.0 dual handset speakerphone system keeps flashing (both on the handsets & one base) that a message awaits. I recently changed providers from shaw to telus & do...
GO into phone setup, and set it to the default setting and the message cleared and the light stopped flashing.
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps you
Best regards
John.
Mar 14, 2011 | GE Lands Phones
I want coad my nokia 2310
Dear Friend,
In these Series,there is no need to Format Mobile.There is no way to Format Mobile.Anyway you can do
  • Go to Settings
  • Click Restore Factory Settings
  • Type Security Code(12345 default)
  • You are Formatted
Do following too for Clearing More Memory
  1. Menu
  2. Messages
  3. Delete Messages
  4. All read or Desired Folder(Your Messages will be Deleted)
Switch Off Phone & Switch ON after few Seconds..You may feel Better Now......
You are Cleared your Phone...(For More you need to Use Flash tool) HOPE THIS HELPED YOU If this Helped you,Do Rate ME.. I like to Know Feedback.. Thanks For Using FixYa
Apr 09, 2010 | Nokia 2310 Cellular Phone
Paper light flashing on my brothers HL-2040 printer. I fanned the paper still keeps flashing
Hello ,
Please follow the below steps to try and clear this message.
  1. Turn the power off on the unit.
  2. Open the front and back cover of the unit.
  3. Remove the drum and toner cartridge from the unit.
  4. Check thoroughly inside for any paper jams or any other foreign objects and remove them.
  5. Reinsert the drum and toner and close the front and back cover.
  6. Turn the unit back on.
If the light keeps flashing you will want to check to see if you need to feed paper through the manual feed.
The manual feed is the opening on the front of the printer, just place a page there.
This should clear the error message on the display screen and allow you to resume normal use of the printer.
Thanks,
Pat
Mar 28, 2010 | Brother HL-2040 Laser Printer
I am getting an error message that black cartridge problem.have changed with two cartridges but still flashing?thanks
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
Mar 15, 2010 | HP Deskjet 6940 InkJet Printer
I did BIOS flash update on my ASUS P5WD2 Premium motherboard. The reason was to fix boot message: “CPU load error. Press f1 to continue” I have two questions: 1) immediately after...
Install the BIOS Flash update, one by one. Like for example 1.0, 2.0 or 3.0.
And if still the problem consist. I think its not your BIOS problem.
Clear the BIOS by disable the JUMPER Setting.
And one last thing change the LITHIUM BATTERY(CR2032) a new one.
If you got the problem again, put a comment so that we can easy understand what is the problem with your MB.
If i am helpful, please rate me.
Thank you very much.
Yboyandrei
Aug 10, 2009 | Asrock 775VM800 Motherboard
My phone wont recieve pictures
your mobile is in software problem pls do the proper flashing and the problem will be shortout.
Nov 06, 2008 | Nokia 6085 Cellular Phone
Flashing osd
It would help to know what the OSD says; is it a message from the monitor or from the main system?
Apr 28, 2008 | E-Machines eMachines Desktop PC
Flash Cards
if its under warranty then you need not worry, you should contact the service centre, but before going there make all backup of your important documents..........
thanks
iqbal
Apr 02, 2008 | Toshiba Satellite A205-S4607 Notebook PC
Sony Cyber-shot  DSC-H9 Digital Camera Logo
126 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
