Question about Alps MD 5000 Thermal Printer
Band printing I live in Moscow using ALPS MD5000 printer for about a year. Everything was fine. But now with the press has not stamped strips every 5-6 mm. Prompt please what is the problem. Thanks for your answer!
  • 83 Answers
Solution #1 is useless. On the ALPS 5000, try cleaning the print head with a cotton swab and alcohol. There might be ink residue on the print elements. If this does not work, you might have a damaged print head.
Posted on Apr 30, 2010
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Is 4330 band printed quite a few
That is a low band printed count for any ALPS printer.
Jan 21, 2015 | Alps MD 1000 Thermal Printer
I use my MD5000 to print simple logos on decal paper. It prints OK in black or white, but any color printing is incomplete. It's as if the color(s) have ran out, but it prints the same specific incomplete...
Replace the cartridge if it has the printhead attached or if not take a straw and puddle the cap where the printer parks the head and turn it off let it soak 1/2 a day then turn on & off 2 or 3 times
John
Nov 05, 2013 | Alps MD 5000 Thermal Printer
Alps md5000 printer driver for pc with windows 7
Sorry, there are no Windows 7 Drivers. There are a couple of work arounds. I use an older laptop with Windows XP. The XP drivers are easy to find on line. There is another way, but I have not tried it. It's using XP compatibility mode in Win 7.
Dec 08, 2012 | Alps Office Equipment & Supplies
My MD5000 doesn't feed manually or auto all of a sudden. Followed the manual. I can print test page from the cd forth e MD500
check and make sure that you have that printer as the default printer. Start,control panel,dvices and printers
Apr 08, 2012 | Alps MD 5000 Thermal Printer
Alps md5000 printer fails to print The machine is setup correctly, when it tries to print the error light comes on and the printer stops
Hello
Did you check the thermal head if its getting hot or not? Another thing is the opto sensor for detecting the presence of media try to clean it first with a brush and then try to print.
DO RATE MY SOLUTION
Jun 30, 2011 | Alps MD 5000 Thermal Printer
I have an alps MD400 and am running xp pro with drivers for xp and can't get the thing to print and need a trouble shooter
There are WinXP drivers for the MD-4000. You can find them in the files section in the Yahoo ALPS Group. There are some conflicts with the Windows XP (Service Pack 3) and the ALPS printers. It is best to connect to a computer running SP2 and has a parallel port. The ALPS group also has the Twain for the Scanner. The MD-4000 does require a carrier to scan things.
Dec 17, 2010 | Alps MD 5000 Thermal Printer
MD5000 paper feeds half way and red light flashes
well first of all you are doing everything wrong you should go to www.computerproblems.com thats where i would go.tell them about your problem and they'll help you.GOOD LUCK OR ASK COMPUTERGUY444 AN EXPERT ON COMPUTER HERE.
Apr 21, 2009 | Alps MD 5000 Thermal Printer
MD5000 to MACBOOK PRO problem
MAC is NOT my forte... however, I do know that ALPS offered THIS a few years after the MD5000 came out:
USB Interface Kit for the iMac OS V8.01 and Windows ($99)
You might find it on ebay etc. and be able to use it (no support with this printer on OS X!).
Apr 08, 2009 | Alps MD 5000 Thermal Printer
Installation disc for win 98 Alps md5000 is currupt and wont install, can you help me
Join the alps and alpsdecal groups at http://www.groups.yahoo.com. The drive is in the files section of one of the groups.
Feb 15, 2008 | Alps MD 5000 Thermal Printer
Alps MD 5000 Thermal Printer Logo
132 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
