I want to be able to Mirror or RAID-1 on 2 different drives, then break the mirror and mark the second drive as an active boot drive. After looking around online, I realize that this process is more...
I understand now, and appreciate your taking the time to clarify.
1.Make a backup disk of the current harddrives contents. This is a Restoration Disk.
Has the basic needed files for the Windows O/S, (Repair), but will also allow for a Full Installation.
2.Desktop, not laptop:
Install two harddrives, put them in a RAID1 configuration. Forget about the 'mirror' image program. Leave them both in there in case of a harddrive failure.
3.Laptop, not desktop:
A.There are some laptops that you press a key, or certain keys, when installing a new harddrive, when the old one has hardware issues, or viruses render it unusable. These key/s are pressed, BEFORE the old harddrive is removed. Allows replacement of that harddrive.
There are some laptops that Do Not! There is a workaround.
The above is to replace that harddrive, and may be used to upgrade to a larger harddrive, IF, certain criteria is met.
B.Use an external enclosure, insert the new 2.5" harddrive. Connect the external enclosure to the laptop via the USB port.
Now use an image 'mirror' program such as DriveImage XML, (Free), to copy over the image of the old harddrive to the new one.
Insert the new harddrive into the laptop. You can use the old harddrive in the external enclosure as a Slave drive.
Still only allows THOSE harddrives, to be used on THAT laptop.
Don't be surprised if you have to Re-Activate the O/S on that harddrive. (New one)
C.RAID configuration on a laptop = No
You only have one interface connection for a harddrive, Generally.
IDE, or SATA
(Some gamer laptops use two hardrives internally. These are already configured in a RAID 0 configuration. More storage space. However, if one harddrive goes kaput, all information is lost. I do not believe you are referring to one of these)
http://www.runtime.org/driveimage-xml.htm
The above is only for reference. I have no working knowledge of this program, just know of it's existence.
Sep 23, 2009 |
Microsoft Windows XP Professional
