Question about NEC VT470 Multimedia Projector
NEC VT470 Projector New Lamp won't turn on even after a reset of Lamp Hours. Lamp type is VT75LP. However with a VT70LP lamp it works.
  • triwestav May 01, 2010
    Thank you for your reply! It is much appreciated.
    After I was able to get another machine for testing I installed the new VT75LP lamp into it and it worked. After I reinstalled the lamp into the projector that it didn't work before and now it is working. I have now tried it several times turning off the lamp and after a while later went back and tried again and it is still working each time. Go figure!
    Maybe the lamp needed a good jolt and a burn in time for it to work, or the Ballast was acting up.
    Thanks again,
    Tony
    President:
  • 1,768 Answers
The lamps on these unit give about 3000 hours of use and will shut down.
New lamp replacement is needed.
Posted on May 01, 2010
    Genius:
  • 1,040 Answers
Dear Triwestav,
Since projector works with VT70LP, Therefore, the new lamp (VT75LP) which you have purchased is may be faulty... First ensure that new VT75LP is working well with another same type of projector....
99% that new lamp (VT75LP) is faulty, So if possible, replace the same with vendor and see result...
Posted on Apr 30, 2010
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
I have an NEC VT470. The projector shut down after the lamp finished. When I replaced the lamp and pressed the start button, the projector does not come back on.
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual.
Good luck
Jan 14, 2011 | NEC (VT75LP) Projector Lamp for VT470,...
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Nec vt470 lamp does not come on. replace lamp, when turned on status light turns red and get 3 beeps. lamp does not come on.
If you replaced the lamp already, chances are the ballast is defective. When you power on the projector with the power button you should see a flicker of light in the lens, or an electrical sound. If you don't you ballast is bad.
Apr 19, 2010 | NEC VT470 Multimedia Projector
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
NEC VT770
Go to MENU and clear Lamp Hours meter.
Jul 10, 2008 | NEC Replacment Lamp Projector Lamp for...
Ballast Unit
Ballast is nothing but it is lamp power unit so here high voltage operating unit. While change the unit please check the voltage ratting and model. connector model and then replace.
Regards,
prakash
Apr 03, 2008 | NEC Replacment Lamp Projector Lamp for...
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 27, 2008 | NEC VT47 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
NEC VT470 Multimedia Projector Logo
203 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
