Question about Kenmore 62062 Electric Dryer
Replacing door light switch
Door light switch is broken,I have new one. whats the best way get to it
  • 10,319 Answers
The top will have to be removed and the front panel as well
Posted on Apr 30, 2010
Interior door light stays on
Door switch stuck open or broken. Spray switch with wd40 to free it if it's stuck, replace if broken
Oct 23, 2014 | 2004 Volkswagen New Beetle Convertible
What part do I need to replace to get the lights to work on a Craftsman garage door opener?
Sounds like a broken or disconnect wire. At least start their. Unplug operator. Take the cover/shroud off, using a bright flash light check all the wires for breaks or disconnects. Repair or reconnect. Also check the bulb screw housing are connect on the back side.
Oct 03, 2014 | Craftsman 1/2 HP CHain Drive Garage Door...
The interior lights stay on because the warning lights say a door is still open but it is closed. Is there any way i can disconnect the warning light, whats the best solution
Hi, There are several causes I would look for.
Each door has a door button that indicates if the door is closed, or turns on the interior light if it is open. There are also contacts on the sliding doors that when they mate, the warning light will go off.
I would try to find the cause.
Do the following.
1 Check to make sure all of the doors are closing properly. You may have one that looks like it is, but is not.
Each door that swings open, i.e. the two front side doors and the hatch should have button switches located in the front door jam of the front doors and one for the rear hatch. Somtimes you will find more then one button.
2 Close all doors
3 Open the driver's side door. (The one that gets the most use), turn on the key but DON'T start the car.
4 find the buttons and push on them on and off to see if the warning light goes out. If it does, then the switch on that door or the door closure position or latch should be able to be adjusted so it works again. If it doesn't, go to #5
(Note: the switch may have a broken off tip, so it may be necessary to replace it. )
5 Repeat for the passenger side door. If necessary go to 6
6 Follow test for the rear hatch. (you may need someone to help on this step.
The sliding door should have some type of "button" like contacts. There may be something lodged into one of them that is giving your a faulty contact.
Hope this helps,
Happy New Year,
Mark
Jan 01, 2011 | 2003 Chrysler Town & Country
2002 Taurus broken antenna and door open/ajar indictor light
Can't help with the antenna. As far as the door ajar goes any of the cars doors can cause this, it is a ting switch that is twist locked into the door latch that fails and gives the warning, it is referred to as the "door ajar switch" You need to have a scan tool hooked up to see which door is causing the problem, as I said any of the four switches can be faulty. Since all the door panels would likely need to come off to find the bad part the scan is the best route.
May 21, 2017 | 2000 Ford Taurus
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Hotpoint WMA46 door problem
From the symptons you describe, it could be a broken or weak spring in the door handle, which ca be fixed relatively inxpensively, that is where i would start, you can purchase one directly from hotpoint, or possibly a local repairer. if that does not cure the problem, then the odds are it will be a faulty programme module.
Hope this helps.
Jan 13, 2010 | Hotpoint WMA46 Front Load Washer
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
DOOR AJAR LIGHT IN THE BOARD WHEN DOOR IS CLOSED
BUTTON BROKEN - REPLACE IT   OR
THE BUTTON  WIRE IS FRAYED AND SHORTS TO THE BODY - INSULATE IT.
Oct 07, 2009 | 2005 Lincoln Navigator
Dryer will not turn on, but is plugged in. Light inside will not illuminate, either. What do I do?
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Jul 16, 2009 | Dryers
Car thinks door is open all the time
There is a small switch inside the door area, and it is obviously broken. The switch is usually held in place by 1 screw, and has a wire clip attached to the interior side. If you replace that switch. your issue should cease.
Simply remove the screw that retains that switch, pull it out of the body, remove the wire clip. and install the new switch in reverse.
I hope this information helps you, and I wish you luck on your repair.
May 07, 2009 | 2003 Mercury Mountaineer
Kenmore 62062 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
