Question about Canon PC-940 Black and White Copier
Copier wrinkles copies
There are now wrinkles in the copies. This just started happening.
  • 1,219 Answers
It cuold be that paper has too much moisture or you nned to replace press roller bushings alonh with cleaner and fixing film
Posted on Jun 02, 2010
Why is my photo copier wrinkling the paper sometimes?
Check the lower pressure roller at the heater unit for damage.Also see to it that the copies are alligned before it enters the heater unit ..
Aug 01, 2014 | Toshiba 6LH58317000-OEM Estudio 355...
Copies are coming out wrinkled - always in the same spot.
You can try to stop the process mid-print. That way if the paper is un-wrinkled before it hits the fuser, then it must be the fuser causing your problem.
The PN for the fuser is FG6-3720-000 and sells new for about $175
Whit
Item, inc.
Sep 16, 2010 | Canon PC-940 Black and White Copier
My copy is coming out wrinkled and threw the top slot by the rollers.where the normal copy would come out. Nothing is ****,paper is full,ink level reads green?? I just made a copy yesterday and it was...
There are about 4 possibilites. The paper in the drawer could have bent up corners, not laying in there good and flat, Fuser rollers bad or uneven spring pressure, something could be wrapped around registration roller or something in the paper path is catching the paper as it goes through the copier. Please rate this. Thanks
Jul 01, 2009 | Canon Office Equipment & Supplies
Workcentre 24 wrinkled paper when copier used
Its a jaming and cutting shits leave some litle bit peace of them///finde of them and remoove
Mar 24, 2009 | Xerox WorkCentre M-24 Color Copier
Wrinkled paper
Many possibilities can cause this....
The Pick Up Rollers could be worn out and not picking the paper up correctly.
Something blocking, or catching in the paper path
The Fuser unit rollers could be sticking, going bad..
The Exit Delivery could be warped, cracked.
After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Feb 06, 2009 | Sharp AR-207 Copier
Paper feed problem Canon PC25 copier
check where exactly it wrinkle .it is most likely to be from the fuser unite.i.e where the paper comes out .if the fuser rollers is having mark or the paper sepration finger ontop of the roller is bend or loses its springing ability
Oct 07, 2008 | Office Equipment & Supplies
Crinkled paper
sound like you fuser is bad
Jul 08, 2008 | Office Equipment & Supplies
Canon PC-940 Black and White Copier Logo
151 people viewed this question
old marine
old marine
