Roper washing machine water will not shut off when filling
  • rickridgway May 03, 2010
    yes it will overflow if not caught in time can turn timer to shut off water
  • Rick Ead
    Rick Ead May 11, 2010
    dou mean willnot shut off the water when filling?
  • Washing Mach... Master
  • 8,220 Answers
The pressure tube that leads up to the water level switch could be obstructed
Posted on Apr 30, 2010
  • Dan Webster
    Dan Webster May 03, 2010
    The water level is controled by a pressure switch. The switch will not work if the hose connected to is is blocked pinched or has a hole in it. As the water level rises in the washer the pressure inside the rubber tube going to the switch begins to build up. The switch has 3 wires. One to the water valve one to the motor and one feed both items. When the water gets ever so high the pressure shuts down power to the water valve and powers up the motor. So what can go wrong? A rat can eat a hole into the pressure tub and it will lose the air tight seal. A portion of the cabinet can pinch the tubing, restricting air pressure to the switch, sand and sediment can get into the tub around the tubing and block the air.
    Solution: Remove the hose from the switch. Blow out the restriction. Rsecure the hose and pump out the water. Then retry.
  • 641 Answers
SOURCE: Roper washing machine hot water won't shut off
An obstruction in the hot water-inlet valve may mean that it's no longer able to shut off and should be replaced. Good luck !
Posted on Sep 11, 2007
SOURCE: roper top load washing machine
Thank you, AlmostBob.
That was the correct solution. For only $17, my washer works again!! To bad for Sears.
Posted on Oct 02, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer fills with water then does nothing
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 27, 2009
  • 64 Answers
SOURCE: my washer won't fill up with water
BIGH57 is right I'm sure but if not you might try checking water level switch. If it is showing full it will not fill. Good luck
Posted on Jun 26, 2009
Dissolu
  • 221 Answers
SOURCE: roper washing machine type 107 won't fill up but 3
check the pressure switch, and the water level sensor
Update ma about your progress
Posted on Jul 25, 2009
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Hot water doesn't turn on to fill the washer
heatman101
Jan 16, 2011 | Roper RAS6233KQ Top Load Washer
Colder water wont shut off after filling up the machine, the hot water does shut off.
Sorry to read about your problem, I hope this helps you out.
you have defective cold water fill valve.. just turn off cold water, until you can have repaired
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Roper RAX4233PQ Top Load Washer
The cold water just trickles out.
heatman101
Oct 14, 2010 | Roper RAS8445KQ Top Load Washer
Roper washing machine type 107 won't fill up but 3
Jul 23, 2009 | Washing Machines
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Sep 11, 2007 | Washing Machines
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
