Can't print to Konica 7030 via Parallel
Looking for some help from a Konica expert. We have a used Konica 7030 copier/printer/scanner. I can copy documents fine without any trouble. But I am not able to switch to ''printer'' mode. There are 3 buttons at the top; printer/scanner mode, fax mode, copier mode. When powered on its in ''copier'' mode which is lit green. I press the printer/scanner button and nothing, it doesnt turn green. Same with the fax button.
I understand that I would need a IP-011 module. I believe we have this because I see the parallel port at the back. I tried plugging in to my Windows 2003 machine with parallel port (LPT) and installed the drivers, but when I do a test print just says ''Error'' in the windows print queue without any details. The printer doesnt move or say anything.
Any advise to help me set this thing up? How do I confirm if I have the IP-011 module? It looks like the one in the manual from the Konica website.
Thanks in advance.
  • 1,110 Answers
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Posted on Apr 30, 2010
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Copies are Very Dark
Are the prints ok? Did you tried to print a test page as follow: Utility -> User Settings -> Print Settings -> Print Reports -> PS Demo Page -> Start. Check this page and if it is looking OK, you isolated the malfunction to scanner area. Try a scan and check the quality, afterwards try to copy from DF and try a glass copy, check the quality.
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 11, 2014 | Konica Minolta Bizhub c203 Copier
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Duplex printing small on one side
is the file type a PDF? do you see the print as a stamp on your copy? ..
Dec 18, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Konica 7030 tray # 4 code
You should contact Konica/Minolta for that information. That requires an tech engineer from K/M to fix that issue if it is possible to do or support.
Jun 11, 2008 | Konica Minolta Office Equipment & Supplies
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
Scanning with Konica 7030
A very general question. Have you triede looking in the manuals to see what is available?
You can find these documetns here:
http://help.bt.konicaminolta.ca/
Feb 06, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
192 people viewed this question
k24674
jasbo
jasbo
