Question about Kenmore 24 in. 15079 Built-in Dishwasher
Drain water smells, dishes dont get clean - Kenmore 24 in. 15079 Built-in Dishwasher
  • 1,998 Answers
At home depot they sell a product called affresh it cleans the inside of your dishwasher from stagnant water smells also check around the area of your chopper sometimes as chopper gets dulled food can build up in that area they also sell an affresh type for washermachines this is a great product for both types of units
Posted on Apr 30, 2010
My dishwasher drawer is not draining the water well after the dishes are washed and then is smells. How can unclog the drain so that it will drain? the filter is clean.
The pump may be worn so it doesn't pull all the water out.
Or a bad check valve so it allows water back into the washer after it was sucked out
Jun 18, 2015 | KitchenAid Double-Drawer Dishwasher System...
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
How do i get it to drain water
new install? check end of drain hose where it mounts to disposer, there may be a plug in there.
If old install, drain at the bottom of dishwasher is plugged, may be plugged in pump which recycles water. If it aint thrown water, your dishes ain't going to get clean.
Feb 14, 2012 | Whirlpool Dishwashers
Hi my washing machine has started to smell of rotten eggs its only 6 months old and dont no what the problem could be
Possible that the smell is coming from the motor/inlet valve/ pump or the capacitor of the motor. so it is important that you need to have a closer observation to find the source of the smell.
Sometimes it can also be due to drain block and so the dirt accumulation could be stinking. If so remove the drain and clean the hose and fitting , back flush the pump and reset.
check for cleaning on the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 13, 2011 | Hoover Washing Machines
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Jun 01, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher really holds smells from soiled foods. Can I put bleach in the dispenser periodically?
First check your main draining system. the entire gas escapes through your dish washer.
Clean the wash chamber with water. Do not try bleach as it may spoil the other parts. If still prefer to use, dilute and use.
For some time use a bucket of 10 to 15 liter and drain the dish washer out let. If the smell not noticed, it is eminating from the main drain system.
May 17, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
I have Dishwasher FDB520RHBO and it smells like rotten milk/eggs each time we wash dishes. The filter is clean and it is less then one year old. What could be wrong?
Check your main drain system, where you discharge the water.
Remove the machine hose and collect the washed water in a bucket. Check the m/c for smelling. No mell noticed then check the main drain.
Apr 16, 2010 | Dishwashers
Kenmore 24 in. 15079 Built-in Dishwasher Logo
180 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
