Question about Cell Phones
My screen is pale and when i press parts of the phone it turns back to the right resolution but it wont do that anymore.
    President:
  • 1,561 Answers
It seems the phone fell from you or you hit the phone surface with a hard surface for your screen to be malfunctioning because it is possible that the screen is not firmed to the panel any longer and you will need to affirm it.
Get a torx6 screw driver.
First thing you need to do is to power off your, remove the baattery, and sim card, Turn the phone over and gently remove the front cover.
After you have pull off the front cover, you can go on with the torx6 screw driver to tighten all the screws that hold the screen of your phone to its panel very well and recouple the front cover back.
Put your sim card and battery to power on, with this it should stop the pale screen.
Take care.
Posted on Apr 30, 2010
My screen resolution wont go back to 1920 x 1080 what do i do?
on the desktop screen do a right click
you will be getting a drop down box
there select screen resolution
you will get a screen opened
there you can find an option as resolution
you can chage the resolution of your screen there
Dec 12, 2010 | Acer AL1716 F Monitor
GeForce 9400 gt, black screen problem
It looks like your graphics card changes the screen resolutions and/or refresh-rate to something beyond your monitor's capabilities.
After installing the drivers and the screen goes black, restart you're computer and press F8 to get the Windows advanced menu boot and choose "Enable VGA Mode".
When booted into Windows, right click on the desktop and select "properties", select the tab "Settings" and pick a really low resolution like "1024x768" and press the "Apply" button (but don't reboot yet when asked to). Next press the "Advanced" button, then select the tab "monitor" and change the monitor resolution to "default" or 60Hz.
Now restart your system and see wether Windows will boot normally. If so, you can change the resolution and refresh-rate back to you preferred values. Whenever you pick a too high resolution or refreshrate the screen will turn black again, but don't worry, don't press anything and just wait 15s, after which Windows will roll back to the previous setting ...
Aug 16, 2009 | Computers & Internet
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
The screen wont turn on anymore. the buttons can sometimes but the screen stays black.
When you say the buttons "sometimes" lite up, do you mean just when they feel like it or only when you power it up or off? And is it making any noise when you power it up? If they're only working when you turn it on and then they go off, then you have a firmware problem and you need to have it re-flashed.. If they turn on and stay on, and it makes noises (like you can hear the keytones when ya press them) then it has got a bad LCD and that's a pretty inexpensive fix (check Ebay for a replacement screen)
May 20, 2009 | Motorola Cell Phones
Cleaned the filter and now wont turn on
there is a switch that when you put the pale back in the right way if the pale is not in all the way it is a kill switch so no water goes on your floor
May 08, 2009 | Kenmore 54351 Dehumidifier
Nokia 6300 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Apr 29, 2017 | Nokia 6300 Cellular Phone
Everything on my compaq presario cq50-215nr laptop got really big after i accidentally hit a couple of buttons on the keyboard and i dont know what i hit. how do i make them go back to normal size
Choose Screen Resolution For higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpg Control Panel: Display: Settings tab: Screen resolution
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
57H81 Red Bleeds, Dull Color, Was Pink
change the l.c.d colour corretion board new £ 400 not worth doing in my opinion part hard to get i stopped reparing these 5 years ago . agro agro agro ebay part not good these sets have a horrible short life
Dec 08, 2008 | Toshiba 57H81 57" Rear Projection...
Laptop screen turn blank
Are you using the nVidia GeForce GO 6150 video card? If this is the case, and I'm pretty sure it is, the NV driver is not being recognized and the system is starting in VESA.
On the nVida, HSYNC/VSYNC frequencies need to be specified, after that the MIXIMUM resolution of 1280x800 should work for you.
Mar 30, 2008 | HP Compaq Presario v3000z Notebook
Phone malfunction
This happened to my mom when she dropped the phone...try taking the battery out of the back...and then placing it back in. Let me know if this works!
Jan 17, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
