Question about GE GSD2200G Built-in Dishwasher
Control Panel does not light up when I engage the lever (cannot start the machine). Checked the circuit breaker - its OK . What could be the problem?
  • 1,998 Answers
Remove the panel on the lower bottom then look at your electical connection at the bottom right check to make sure you have power going into the machine if you do have power could be the control board behind the panel
Posted on Apr 30, 2010
Machien wont start, fill up or anything please help
just had same problem, washer was working and when new load was started it would not start. circuit breaker popped and reset it. no lights on panel and circuit breaker good in house. pulled power panel off and opened circuit card and notice black burn spots between cards which looks like the control panel is fried now. Cost about 200 to order, not knowing other costs if repairman fixes it.
Oct 02, 2010 | Washing Machines
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
No power not coming on. circuit braker is not kicked.
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine. Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve ?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tab to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary with correctly rated thermal fuse.
Mar 21, 2010 | GE Dishwashers
It will not start
First check the breaker to the machine.
If you have an exposed power source to the machine such as a plug or junction box open the box and check the wiring is intact and not rusted etc. Take care here and shut the breaker off first.
No go so far?
Not the float valve either?
Not it?
Mar 21, 2010 | Whirlpool Dishwashers
Brake lights and cruise control stopped working at the same time?
Ther is a recall on the brake light switch it makes the cruise control not work too. but Chevy only recalled the Brake lamp Switch. Recall #09049.Hope this helps.
Jan 01, 2010 | 2006 Chevrolet Colorado
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Whirlpool Duet Dryer
Friend,
huuum At your service!
You said:
Everything was working fine, now we get no panel lights, the dryer light doesn't, dead in the water! Checked the plug...unplugged it and plugged it back in. Checked the circuit breaker...ok. What next?
I'm sorry to tell you that you need hands on service.
If I were there hands on I could diagnose the problem.
You may have an electronic malfunction and that only a trained technician can diagnose!
SORRY!
Bless You,
huuum
Please give me a good rating before you sign off
thank You
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE GSD2200G Built-in Dishwasher Logo
114 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
