Question about JBL PSW-D110 Speaker
JBL PSW-D110 Humming Loud
Hi I have a JBL PSW-D110 and it is humming loud. The fuse is not blown. It has always been connected to a surge protector power strip. The power LED lights up in green... I have some knowledge of electronics but I don't have the schematic for this unit.  Besides if you could point me directly to the faulty components it would save me lots of time and frustration.  Please help.
Thanks,
D. Mark Ellis
  • CALSunbelt Apr 02, 2008
    Hi Dan,
    I ordered a JBL C6KIT service kit which includes:
    C6, 10uf 100v bi-Polar electrolytic cap
    C24, 100nF ceramic cap (replace if missing from the board)
    R23, 20K ohm 1/2 W resistor (replaces 4.7K ohm on the board. On older boards, this part may be located between the filter caps and is standing on end)
    R46, 47 ohm 1/4W resistor (replaces 4.7 ohm on the board)
    I will give it a try and keep you posted. Thanks for getting back with me with your suggestion.
    Thanks,
    Mark
  • 4,234 Answers
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
Posted on Mar 26, 2008
  • ABRsvcs Apr 02, 2008
    That kit addresses the most common failures and should resolve your problem. Update this if it does not and we'll look further.
    Dan
6ya staff
SOURCE:
Hi, Here's the problem with my PSW-D110. When I plug in the power cord I get a loud humming sound and the speaker thumps every couple of seconds. Anyone know what the problem may be. Thanks, Tim
I would say it's a case of bad filter capacitors in the power supply. Without the capacitors, the AC power line doesn't get smoothed out enough when converted to DC by the supply, and you hear the hum that gets through. I have never worked on on one of these so I can't tell you how to open the case to get at the supply. It's not always a simple job. But if you can get at those caps and check them, you'll probably find them at fault. It's not a difficult job to remove and replace bad capacitors if you are comfortable using a soldering iron. Just make sure that replacement parts have at least the same voltage voltage rating and capacitance values as the originals. It never hurts to go higher by a little, but not lower.
Feb 24, 2011 | JBL PSW-D110 Speaker
No output from d110
You can use a cap of same or bigger voltage,
Oct 17, 2008 | JBL PSW-D110 Speaker
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
I'm getting a loud "popping or clicking when i plug the sub in. also i noticed the green light comes on immediatly when the loud popping begins. the loud popping dosen't stop untill i unplug it
What's feeding it? The sub comes on automatically when it senses a signal, which seems to be what it's doing. Perhaps the loud clicking is originating at the other end of the cable.
Jan 27, 2010 | JBL PSW-D110 Speaker
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
JBL PSW D100 blown fuse
Not likely. There are no fuses according to the instructions I found for the D-110. I assume they're about the same.
Try it with nothing attached anywhere except the power cord. No light immediately = dead.
Nov 10, 2008 | JBL PSW-D110 Speaker
JBL d110 /w no sound output
There is a standby indication that activates after 10-15 minutes without any input signal. I suspect that might be what the red light is telling you - no signal.
Loud hum from a loosened cable is normal as hum usually means there's an ungrounded connection somewhere acting as an antenna and the amp is doing its job to amplify what it thinks is a signal, in this case 60hz stray ac current is being sensed nearby. It's a good sign that you get hum from the sub because that means the amp is alive.
Avoid manipulating cable connections with the Sub or Receiver turned on as you could introduce a static spike that could harm any connected equipment.
Are you certain a bass signal is making it into the sub? The complexities of modern AV receivers vary in how you configure them to direct LFE to a sub. Bone up on that end of the chain.
Or, just hang a CD player on the Inputs of the sub and play something with a reassonable amount of Low Frequencies.
>>>> Be advised that this way of testing has NO VOLUME CONTROL because amps without volume controls always operate at maximum gain, relying on your external controls to attentuate it (hence, the loud hum from a loose cable); so choose a track that eases into the loud parts with some quiet parts up front and BE READY TO PAUSE THE PROGRAM AT ANY SIGNS OF STRESS. <<<<
A living sub will produce only muffled rumble in the absence of other speakers producing the higher frequencies which carry the intelligence of the signal. If that works, back to the receiver for settings. If not... sigh.
For hum problems, even those you cause yourself:
Disconnect all inputs to see if that helps. If it goes away start with the signal cables and add in things until it comes back.
Sometimes the reversing the orientation of the AC plug can help with hum. Or it could be something like a loose or high resistance connection internal to the sub. Good luck.
Jun 17, 2008 | JBL PSW-D110 Speaker
No output from d110
Hi Chadwik
The fact that you do get hum when you partially remove one of the RCA's would tend to say that the output stages are working ok. Is the hum "solid" and bassy, or distorted?
There are a few issues that these subs have had, mostly to do with capacitors in the power supply failing. If you are up to it, I can talk you through repairs to it.
regards
robotek
Jun 16, 2008 | JBL PSW-D110 Speaker
JBL PSW-D110 Speaker Logo
826 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
