Question about Pantech Matrix Cell Phone
My full keyboard slider has come off and i was wondering if you can fix it easily or need to just take it to ATT and get replaced
We bought an L shaped desk in May 2016. The keyboard sliders and shelf has fallen off 3 times.
You can't. These are made cheaply abroad and the companies that sell them have them branded as theirs. I see they are sold by Office Depot, Amazon and others, but there is no manufacturer website. Just take them into Home Depot and speak to one of the associates in the Fixings and Hardware Department. They will find you a replacement.
Realspace Mezza Collection Google Search
Apr 19, 2017 | The Computers & Internet
Keyboard mistyping issues
1. Change to United States-International keyboard layout.
Manually change to United States-International keyboard layout
2. Use the Microsoft Fix it 50558
3. Confirm if the Keyboard is wired or Wireless
Information:
Ensure that batteries are new for the wireless keyboards as drained batteries can
cause delay.
Slow computer can also cause the issue. Check if computer is slow and perform necessary troubleshooting steps related to performance after following below provided troubleshooting steps
Steps:
Clear Turn on Filter Keys, or adjust the settings to a quicker rate for Windows Vista and Windows 7
Clear the Use Filter keys check box, and then click OK for XP
adjust your keyboard's repeat delay and rate settings
Drag the Repeat delay: slider to Short
Drag the Repeat rate: slider to Fast
Click OK.
Close all windows
Is issue persists, Reinstall the Drivers
Follow below steps :
http://www.wikihow.com/Fix-a-Keyboard-That-Has-the-Wrong-Characters
Mar 22, 2014 | Dell Inspiron 1525 Laptop
The track boll and keyad of my blackberry set 8320is not working i can juat see the screen when wither i fix it on charger or when i remove it can u please tell me some economic solution........?
http://www.truesupplier.com/wholesale-oem-full-blackberry-curve-8300-8310-8320-black-covers-c-890-p-1-pr-19189.html
http://www.truesupplier.com/_search.php?page=1&q=blackberry+8300+trackball
I've purchased items from Truesupplier.com before and they provide excellent service.
You'll need to purchase another keyboard/housing and a trackball for your phone.
You'll need a T6/T4 screwdriver. This can be bought from Lowe's/Home Depot.
There are several videos on youtube that show the replacement of your housing.
This is the easiest way to fix your keyboard and trackball.
May 16, 2011 | Valor Fits Blackberry Curve 8300 8310 8320...
Please give me everything information about LG GW 525
The new LG-GW525 is a Slider QWERTY Touchscreen Phone with enhanced messaging and social-networking capabilities.It is a 2.8-inch full touchscreen phone featuring a 3-megapixel camera.There is no WiFi in it. The main features of the new LG-GW525 Slider QWERTY Touchscreen mobile phone are:
  • RF Band: GSM 850/900/1800/1900,UMTS 900/2100
  • Display: 2.8-inch full touchscreen TFT display with 240×400 pixels resolution
  • Dimensions: 106.5x53x15.9 mm
  • Slim and Compact design
  • Slider QWERTY keyboard
  • Enhanced messaging and social networking features
  • Push e-mail and instant messaging
  • 3 megapixel camera
The detailed specifications of the new LG-GW525 mobile phone are:
  • Network:GSM 850 / 900 / 1800 / 1900,HSDPA 900 / 2100
  • Dimensions:106.5 x 53 x 15.9 mm
  • Weight:125.5 g
  • Display:2.8 inches TFT resistive touchscreen, 256K colors,240 x 400 pixels
  • Full QWERTY keyboard
  • Accelerometer sensor for auto-rotate
  • Memory
  • Internal:40 MB
  • Card slot:microSD (TransFlash), up to 16GB
  • Data
  • 3G HSDPA 7.2 Mbps
  • Bluetooth v2.0 with A2DP
  • USB v2.0 microUSB
  • Camera:3.15 MP, 2048×1536 pixels
  • Stereo FM radio
  • Colors:Blue on Black, Red on Black, Silver, Pearl White
  • MP3/MP4/AAC/AAC+/EAAC+/WMA player
  • MP4 player
  • Document viewer (DOC, XLS, PPT, PDF)
  • Battery:Standard battery, Li-Ion 950 mAh
  • Stand-by:Up to 500 h
  • Talk time:Up to 5 h
Mar 29, 2011 | LG GW525 Cell Phone
When I slide my LG Neon phone up to use the keyboard the screen's back light will shut off or flicker, but if I close it it will work just fine. I was wondering how to fix this.
Examine the phone carefully to be sure the slider is not coming apart. You may be catching a wire or something that's causing the issue, and tucking it back into the case of the phone could resolve the issue.
If that doesn't work, it sounds like your phone's hardware is starting to fail. It will probably not be cost effective to repair it yourself. Slider phones often have these issues. If you can, seek a warranty replacement, or look for a new phone.
Mar 03, 2011 | LG Neon GT365 Cell Phone
I have a sony vcr model slv-799hf, with a error code displayed 30109. The tape will not rotate. Dan: dodge1989@att.net What does this error code mean?
SYMPTOM: Unit does not load or eject. RESOLUTION
Replace slider with new part number 397744203
SYMPTOMS
No playback video.
RESOLUTION
Located and removed solder short between pins 9 and 10 on IC1201.
For error codes for this model, you might need the full service manual.
Contact me at billyjones@fletchersite.com if you need this.
Mar 09, 2008 | Televison & Video
Volume drops
um, it might be, simple or stupid, thought check the sides of the keyboard, the optional buttons, the volume down, might be stuck, hope it helps
=D
Feb 23, 2008 | Logitech Cordless Desktop S 510
Dubble den kenwood dvd player
There is a bulletin on the mech which requires 2 springs to be replaced. When you install disc the cd pushes on two sliders that push on switches to detect the position of the sliders the springs pull sliders back to original position. Sometimes the slider may stick due to not enough spring tension and possible restriction due to dust dirt etc. This would be a possible problem for your symptom . kstahl65@att.net
Feb 07, 2008 | Kenwood DDX7015 RB DVD Receiver With 6.5"...
Help
Is this the one with the slide power unit? If so, the slider could be defective. First, have a look at the slider....is it full of gunk? If so, you might be able to clean it out. With the power off, get some brake cleaner from the local auto supply guy. Spray it liberally into the slider and move it around...The dripage will be messy. Put a bunch of paper toweling under it to catch the stuff. It is not flammable but you should wait for it to dry for a few minutes before restoring power. Still with the power off and the motor/fan exposed...does it turn easily? If not, you may have an issue there. Gunk or bad bearings. Fix that up.
Nov 16, 2007 | Frigidaire HV2736B Kitchen Hood
Pantech Matrix  Cell Phone Logo
115 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
