Question about Kenmore 62602 Electric Dryer
What can I do if the door switch is broken? - Kenmore 62602 Electric Dryer
  • 1,998 Answers
You have two options you can replace the door switch or take the two wires on the inside and join them together this willcause the dryer to always run even when the door is open if you need to replace door switch try allbrands appliance parts there pretty reasonable and i find much better inthere pricing
Posted on Apr 30, 2010
Electric dryer will not start
If the filter chute or vent to outside is clogged the skinny white fuse mounted on the blower next the the control t-stat melts. This kills power to the door switch circuit. The door switch circuit stops the motor whenever the door is opened using a door switch. If the door switch lever is broken or the door switch is broken she won't rune either. Now here is my home movie and whirlpool dryer page:
DAN'S DRYER REPAIR PAGE
Apr 28, 2013 | Whirlpool Dryers
My frigidaire stackable dryer wont turn on when i turn the start switch any clues?
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Jul 20, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer drum will not turn
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jul 20, 2009 | Dryers
Dryer just stopped
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Will not start up. It has power to it.
Check the following to address this issue.
Door switch / Door switch actuator lever
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If all the above inspection check out ok and, the door switch or actuator is functional, replace the timer or control board.
Jun 18, 2009 | GE Dryers
Frigidaire Crown dryer will not start. Has power to it
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Jun 11, 2009 | Frigidaire Electric Dryer
Stoped working
May 30, 2009 | Miele Dryers
Drum doesn't turn, start switch turns dryer on when held on but dryer shuts off as soon as start switch is released.
3. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Dec 02, 2008 | Dryers
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Kenmore 62602 Electric Dryer Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
