Question about Onkyo TX-V940 Receiver
Protect is on how do you turn off or reset? - Onkyo TX-V940 Receiver
How to change password on blackberry when you don't know the password?
If you or a user turns on content protection for a BlackBerry device that is running BlackBerry Device Software version 4.3 or later, you can reset the BlackBerry device password using a BlackBerry Enterprise Server version 4.1 SP5 or later. The BlackBerry Enterprise Solution uses the remote password reset cryptographic protocol to reset the BlackBerry device password when content protection is turned on. The BlackBerry device does not prompt the user for the old BlackBerry device password.
The remote password reset cryptographic protocol is designed to provide the following features:
* permit the BlackBerry device to encrypt the content protection key again with the new password, without the old password being available
* prevent a hardware-based attack on the BlackBerry device from recovering the content protection key without knowing either the BlackBerry device password or the IT policy private key that the BlackBerry Enterprise Server generates for the BlackBerry device
* prevent the BlackBerry Enterprise Server from accessing any data that a potentially malicious user could use to recover the content protection key
To reset the BlackBerry device password, you send the Specify new device password and lock device IT administration command to the BlackBerry device. You should send the IT administration command to a content-protected BlackBerry device that is in the possession of the BlackBerry device user only. If you send the IT administration command to a BlackBerry device that is in the possession of a potentially malicious user, that user can use a hardware-based attack to recover the key pair that the BlackBerry device created when it received the IT policy. The potentially malicious user can use the key pair to decrypt all the data on the BlackBerry device.
* Process flow: Resetting a BlackBerry device password when content protection is turned on
Proceed on this link : ID PASSWORD RESET
Aug 06, 2011 | RIM BlackBerry 8703e Smartphone
How do I enter the Test Mode on my RISO 790 duplicator?
Do you mean into the unprotected mode?, if so
Turning OFF Protect mode in a Riso MZ 790u (and other models I'm sure).
1. Go to Admin Tab on the main console screen and scroll to the "Protect" button.
2. Select (press) the "Protect" button on the screen; printer will go through a reset function (takes about 3-5 seconds).
3. After printer is finished "resetting", pull out one of the master disposal boxes (doesn't matter which one).
4. Press the "Protect" button again.
5. the screen should say "Protect = Off"
6. You're done and your machine should be un-locked now.
May 11, 2011 | Office Equipment & Supplies
How do you reset the protection mode
The protection function has been activated because it has sensed an output load problem, turn receiver off and remove the speaker wires, this will reset the protection circuit. Now! turn the device on and turn the volume right down, if the protection mode stays off it indicates a short in the speaker wire or one of the speakers, but! if the protection circuit comes on with "the speakers and wires dis-connected" it means there is a short in the audio outputs in the receiver itself, this can only be rectified by having the parts replaced.
Mar 02, 2011 | Sony STR-DE585 Receiver
What is the color password protect - diable overide - reset turn off?
Hi
Password protect is to make a password to the menu and only you can have access to it
disable overide is to overide the toners when are near end
and reset is to reset the menu to start menu
Jan 03, 2011 | Xerox Phaser 8560MFP Laser Printer
My kenwood kdc-mp53u flashes PROTECT whats wrong with it?
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Apr 11, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Error code "protect" comes on the scree when turned on
This a memory problem ,try to look for the reset button and press it . If you can't find the reset button then the other option is unplug the unit for 24 hours the purpose is to reset and dessipate or drain the charged current .
Hope it may help you;
Regards;
VOTIT
Jan 08, 2009 | JVC FS-G5 CD Shelf System
77 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
