Question about Dell (0F146) Internal DVD Drive
DVD will not eject from slot loading dvd in my Dell M1330 laptop
T-Mania
  • 42 Answers
SOURCE: dell xps m1330 dvd won't eject
Does windows pick up the drive? If so right clcik the drive and select eject. Apart from that if theres no pin hole you could try re-installing drivers. Go to device mangaer and right click the dvd drive select uninstall then reboot let it re-install itself and try ejecting again. If the normal button doesnt work though it may be a physical issue.
Let me know how it goes.
Posted on Mar 23, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Posted on Jul 21, 2009
Chittaranjan
  • 62 Answers
SOURCE: DVD won't eject from Dell m1330
1. If the CD/DVD drive tray not open.
Open "My computer" windowsand select the CD drive . "Right click" onthe CD drive.You will get apop up windows with the "Eject" option.
If it open that's means the power supply is ok
2. If the DVD drive is not showing on my computer windows or the DVD is not detect the CD/DVD disk
Tofix the problem we need to delete the UpperFilters andLowerFiltersregistry key for more details about the troubleshootingstep please follow the below link.
No longer access the CD drive or the DVD drive
3. Make sure the cables (IDE,SATA) etc are seated firmly and jumpers are set correctly (slave master...etc).
4. After follow the above steps if you still face the same problem then need to contact the local hardware vendor.
Regards
http://ithelpdesksupport.blogspot.com/
Posted on Aug 09, 2009
anjana03
  • 361 Answers
SOURCE: Dvd drive is not reading and also ejecting out !
i think it is not softwere problem. rubber of moter is loose/extend then new so take it on technican.
Posted on Oct 30, 2009
  • 356 Answers
SOURCE: dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
Posted on Jun 03, 2010
I have Dell XPS M1330 Laptop.. When i insert a DVD it will eject back quickly.. It does recognize at all..
Is it a slot load?
this is a common manufacturing defect on slot loads. ask for replacement.
I had this problem on brand new macbook pro. there are thousands of other user with same problem.
solution= get it replaced before warranty expires.
Jul 14, 2011 | Dell XPS M1530 Notebook
Dell xps m1330 dvd slot cannot load. if cd/dvd is inserted, it is ejected instantly.
Update firmware version from the support site. support .dell.com enter your "service tag" to get proper device driver then flash or update latest BIOS software from the support site aswell
Sep 29, 2010 | Dell XPS M1530 Notebook
My PC won't allow me to right click to choose the eject option for a CD. I want to know if there is a way to remove the CD manually.
The DVD drive itself has a small horizontal 'eject' button that you can press to eject the disc.
If the button fails the disc is stuck however the DVD drive will have a small hole near the eject button- about 2mm in diameter. Straighten a paperclip or similar and push into the hole until the disc drive mechanism releases and opens.
Thanks,
Javaftper
Aug 07, 2010 | Dell XPS M1330 Notebook
Dvd will not eject from slot drive of dell vostro 1510
May 24, 2010 | Dell Vostro 1510 Laptop
My dell laptops xps m1330 dvd player is not working
Verify that you have the last firmware (A14) on the Dell Support web site. Then check the CSS status of the DVD (should be unlocked) with this utility
http://www.digital-digest.com/software/download.php?sid=2&ssid=0&did=1
and finally verify that the DVDs are actually readable, and that the DVD reader works (try reading / burning a data CD-ROM or data DVD).
Check also that the video player software is set to the correct region and there are no errors in the Event Viewer (Hit Start, choose Run, type EVENTVWR.MSC and Enter). DVD events should be either under System or Applications.
Apr 15, 2010 | LG GCC 4320B CD-RW/DVD-ROM Burner
Dell xps m1330 dvd drive will not eject cd inside
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Dvd stuck inside slot drive, system had crashed
hello..to get out you`re CD/DVD its very simple you need a small Pin like a paper clip then find the small hole the front side of DVD/CD player and push the hole using the paper clip..about this question kindly Verify>(plus i had already installed the new hard disk because the old one crashed)..what is it??...Thank you
May 08, 2009 | Dell XPS M1330 Notebook
Dell xps m1330 dvd won't eject
Mar 23, 2009 | Dell XPS M1530 Notebook
MY LAPTOP WILL NOT ACCEPT MINI CDS.
http://www.amazon.com/Pocket-Adapter-Drives-Player-Cartridge/dp/B000067VBS
Jan 15, 2009 | Dell XPS M1330 Laptop
Dell (0F146) Internal DVD Drive Logo
175 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
