Question about Pioneer DV-464 DVD Player
A blue line at the top of the tv screen that won't go away
There's a blue line at the top of the tv screen with a picture of a film camera in it. it won't go away and i wanna watch my movie! pleeeaase help. thanks
Flash goes every time, even when there is no lightning bolt in the screen (for lack of better terms). Also a few photos turn out blue that were taken indoors.
210 wide camera is auto detect the environment. If you face it under bright light, the flash will auto off, if away from bright light, it will auto have flash. for photo have blue hue do show me the image, i take a look
Jan 10, 2014 | FUJIFILM Instax 210 Film Camera
Sanyo DP46848 im stumped lol... with nothing connected ( aka ) cable and or any other components .. just plug and turn on .. the screen has a solid blue bar from top to bottom with small white lines in...
Although you have not posted a picture, I believe you may have a screen or LCD panel problem, the panels have film connections that go from the t-con module, through the panel control pc boards then through thinn film connectors from the lcd screen. Likely this is the problem.
Oct 29, 2013 | Sanyo DP46848 LCD TV
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
I have a RCA 32V432T 36in...the screen is light blue with white horizontal lines...it looks like a film in front of the actual picture...there is still audio though. what's going on?
Hello
There are two main causes for this fault. The first one is, advanced screen voltage to the screen grid of picture tube. The second one is leaky blue video output transisotr.
Just open your TV, and locate the screen control. It usually can be located with LOT [Line Output Transformer]. There will be two adjustable controls integrated to this LOT, marked as screen and focus. Out of which, the lower one will be for screen adjustment, and the upper one for focus adjustment. Just rotate the screen control [the lower one] to a little counterclockwise, so that the thin horoizontal lines on the screen just fade of. Adjustment is critical and should be done with care, and a small movement may just be enough. If it does not help you, repalce the blue video output transistor. This part can be located at the bace card [the printed circuit board fitted to the neck of the picture tube]. Locate it, replace it. OK.
Apr 17, 2011 | RCA 32V420T 32" TV
A thick blue horizontal line appeared in my LCD screen and won't go away. I can still take pictures and they print out fine, but how can I get rid of the blue line?
This is probably a problem with your LCD monitor or the connections to it. Does the blue line show in all situations such as record, playback, and menu mode?
Test your monitor by plugging into your camera the TV cord that came with your camera. Connect to a TV and use it as a monitor when your camera is on. be sure to switch to the TV to channel three or video to get a picture. Check the different screen modes: record, play, and menu. If the blue line does not appear on the TV then there is damage to your monitor or its connections. My guess is you won't see the blue line on your TV since you get good prints. If you are on warranty, get it fixed. Otherwise, you have a choice between paying for a repair or living with it. Good luck.
Nov 27, 2009 | Olympus Cameras
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Sony KP53S35 blue projector problem
You need to replace both convergence ICs. They are STK392-110 they are located on the g Board on big heat sinks designated as IC809 and IC810. You can get new replacement ICs at the following link and they provide free unstalation instructions with pictures plus free on line tech support. here is the link. If you cant access the site right away try again cause they get super busy in the evening with customers placing orders.
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Sony KP-53S25 53" Rear Projection...
Dark Screen and red and blue lines
Those lines tell me that you may have a leaky electrolytic capacitor in your vertical circuit.
Feb 10, 2008 | Mitsubishi VS-60607 TV
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Pioneer DV-464 DVD Player Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
