Question about Sharp XR-10X Multimedia Projector
Flashing leds no picture
Was in the middle of a game when the projector just stopped working . i let it cool down and tried to power up but nothing just flashing red leds. after waiting an hour or so the leds were normal and i tried to power up and then all we get is flashing green leds ?
  • 3 more comments
  • jesse81 May 10, 2008
    i was playing my xbox 360 on my sharp projector and it just went out on me. i replaced the bulb with a new one a couple months ago.i checked the bulb but its not messed up in any way.the led light flashes red but when i try turning it on,nothing happens
  • Kid Capri Dec 28, 2008
    I tried to reset the lamp using procedures on page 45 in the manual, but still got flashing green lights on lamp and power/standy mode. there is no description for that in manual other than warming up... once warm the lamps go solid then they start blinking again and just keep going thru that cycle... then after about 5 minutes they both turn red. And this is with the new bulb! ??
  • chad008_9 Jan 26, 2009
    Its a fairly new bulb and i put it in and was watching a movie just fine and then it went off. I thought that the new bulb burned out. It still looked good but when i put it back in all I get flashing green lights on lamp and power/standy mode. Then the lamp go solid then they start blinking again and just keep going thru that cycle... then after about 5 minutes they both turn red.
  • Anonymous Feb 08, 2009
    I have the same problem as those listed above, the bulb is fairly new and it just went out when my wife was watching tv on the projector. I pulled out the bulb and it does not apper to be blown, what is the deal
  • Marnus Jacobs
    Marnus Jacobs May 11, 2010
    Did all the led's flash red when it switched of ?
    Does all the led's flash green when switched on ?
When You changed the bulb  you have to reset the bulb timer , that why the light is flashing red , look at your manual and reset the timer , and the picture , changed bulbs myself before i found what the problem was ,
Posted on Sep 17, 2008
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
LP 240 stopped working. No lights, no fans, nothing.
Please describe the status of the LED indicator. No LED would indicate a failure of the power supply. I can help you with that.
Flashing red would indicate a fan/lamp problem. Some lamps fail prematurely before the lamp hours are up.
If it is the power supply, no lights at all, I can get you running again. These units have fragile power supplies that can burn out with the slightest power surge. A UPS goes a long way to save future headaches.
Jan 16, 2009 | InFocus LP 240 Multimedia Projector
Infocus led diagnostic
it might be overheating. clean off the dust filters (bottom towards the front). if there's not enough airflow to cool it down, the projector will shut off to save itself from damage.
Jul 01, 2008 | InFocus LP210 Multimedia Projector
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
641 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
