Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore side by side dirty water
I install a new water filter after a year except I forgot to turn it when I ran the 3 gallons of water through it. I did see no problem with the water. However, when I did turn after running the water through it, it now always seems to have a film of something floating in the newly dispensed water. What do I need to do. I have run about 20 gallons of water through it and it still has the problem. Is it a broken membrane in the filter and I need a new filter(thought I read that somewhere)? I purchased a kenmore side X side three years ago and after hooking it up noticed stuff floating almost like "jellyfish" floating around in the water. After running lots of water the problem never got better. I then bought a new PUR basic filter. still the same problem. Probable should have contacted Kenmore right away, but we have a reverse osmosis system so the drinking was never an issue, until I started looking it up and found someone else that had the same problem.
  • 1 more comment
  • Anonymous Nov 01, 2008
    I have the same problem with particles floating in the water. We have replaced the water line and changed filters many times as well as flushing it many times. Is there something we are missing?
  • ysinghv Mar 26, 2009
    I have the same problem, chnaed water filter several times, but still see foreign particles in water, with or without the filter.
  • Anonymous Apr 16, 2009
    I have the same problem, I changed the filter number of times but still have things floating in my cup of water.
    President:
  • Kenmore Master
  • 2,651 Answers
The problem might be linked ot your reverse osmosis system itself, something about filtering and storing previously filtered water, which if i remember correctly creates a "harmless" bio film the consistency of what appears to be brine shrimp sized particles floating in water. so i would remove the filter from the refig and flush out again.
Posted on Mar 25, 2008
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Whirlpool Side by Side- semi-translucent tape likedebris in water
Sounds like the plastic from the icemaker is chipping off the unit in the ice making process.
If your water is running clear except through the refrigerator that is my suggestions. Although normally the plastic color is blackish.
Jan 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Filter ejection
it shoulnt eject they are usally screwed on
Dec 14, 2007 | Kenmore 50522 / 50524 Side by Side...
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
The original cap for the filter, was supposed to be a plug bypass, for application of outside undersink filter. Using, this, one can check to see if the filter was the contaminant here. You need to be, more specific, to explain a problem. Something is too too generasl,,, color, consistancy, odor, quantity, filter has a fine fine filtrationl unit on the outlet, and if defective the charcoal residue may come out. You can remove filer and pass suppy water thru and review the effluent coming out. ??? Regards, fmauka
Sep 19, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
191 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
