Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Damage to tv
I was cleaning my tv and some glass plus got down in the bottom of tv screen now all it is doing blinking the power button and the osp button.
  • 42 Answers
Unplug it and wait 4 or 5 hours. The Glass+ should evaporate and there should be no damage done.
If the problem continues after waiting, you need to take the TV in for service.
Posted on Apr 30, 2010
I cleaned my projection panasonic magnavox tv with windex, not there are streaks coming up from the bottom of the screen followed by black spots, did i damage it completely, should i turn it off, and let...
Never spray directly on a screen. If the solution seeps into the underside (back etched side of the glass) it could damage the surface. You may have to get to the inside from the rear projection area or lift of the front glass screen and remove it completely. Usually the Rear surface of the screen is etched and can be wiped clean. Go to Bed Bath and get a good streak less windows cleaner. Spray it on a soft cloth and wipe the front and/or back glass. Wipe dry with a CLOTH, not a paper towel, and when dry use a flash light to see any streaks or blemishes left behind. Clean again is necessary. Do not apply pressure, gently clean and try not to cause scratches as they show up when the projection device flashes the image on the glass portion. Put it all back they way it was and enjoy.
Dec 18, 2013 | Philips 9P6040C 60" Rear Projection...
Can we seperate the tv from the speaker to transposrt it up stairs?
You should be able to take the screen off and the top black plastic shroud that holds the mirror off to transport it.
1) To do this, you will pull the speaker grill cover off on the front bottom.
2) I think there are four screws at the bottom of the screen holding the bottom in place. Use a 1/4" socket.
3) Disconnect the wire harness going to the screen by squeezing the tab on the connector - very easy to do.
4) Remove all the screws on the black plastic shroud - about 8 of them. Have someone hold your screen and gently lift the screen off. The black shroud I think still has some screws holding it in place that become visible once you lift the screen off.
5) Once the screen is off, there should be a set of screws that are holding the shroud down. Remove those and gently put the shroud on the floor where the mirror cannot get damaged.
6) Installation is reverse of the above.
Note: This would be a good time to clean the mirror and tops of the CRT bulbs. It will make your picture much nicer if it hasn't been done. Use a non streaking glass cleaner on the mirror and bulbs. For the screen, just wipe it down, don't spray it with glass cleaner.
Feb 26, 2011 | Toshiba 42H83 42" Rear Projection...
We were watching tv and there was a pop the screen went out and now there is a red button just to the left of the power button blinking and making a clicking noise?
A pop means that a component inside the tv has failed the big way - it has exploded. The red button that blinks is the status light - it signals that a massive short has been detected and the power source of the tv has been forcefully shut down. The clicking comes from the source, it keeps trying to start so the protection system keeps shutting it down.
The failed component will have to be identified, replaced and the rest of the tv tested to check what other damage has occurred and fix it. This is a job for a pro, no way you can fix that yourself. Unplug the tv from the wall - leaving it powered only makes the damage greater - and call one.
Jan 23, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Why does my HP 1500 prints a test page every time I begin touse it???
HI
As soon as the printer prints the test page or alignment page place it on the scanner glass (Place the printed side down) before that Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
After That press scan on the printer button panel it will resolve your issue.
Try to double check it by turning it off and turning the printer back on after 2 minute's. If still the problem exists call HP Total Care 800 - 474 - 6836 if you are from US/Canada.
) Lift the lid of the product.
2) Place the top of alignment page face down in the right front corner of the glass.
3) Place the alignment page face down
4) Close the lid.
5) Press the Start Scan button.
6) The Power button light will blink during the alignment process.
7) After the Power button light stops blinking, alignment is complete.
Aug 04, 2010 | HP Office Equipment & Supplies
Dark screen, no blinking cursor
press 2nd and the down button (hold down button)
Jan 14, 2009 | Texas Instruments TI-83 Plus Calculator
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
I HAVE A GATEWAY LAPTOP-M-SERIES-15.4"-WHAT CAN I USE TO CLEAN MY SCREEN-DO I USE SOAP&WATER OR MAY I USE MONSTER ICLEAN.
To clean your notebook computer's screen, use a soft cloth dampened with water. Be sure to dampen the cloth; ***** squirt water directly onto the screen.
Warning: The notebook screen is made of specially coated glass and can be scratched or damaged by abrasive or ammonia-based glass cleaners.
Regards
Mar 09, 2008 | Computers & Internet
Water stain inside of screen glass
Yes, you can check with ctechnicians.com for instructions on disassembling.
Dec 23, 2007 | Hitachi 60EX01B 60" Rear Projection...
Printer problem
Does the line appear while copying or printing ?
To isolate the issue try to print a self test page :
1. Press and hold the Cancel button and then press the Start Copy Color button.
2. Release both buttons. The self-test page prints.
If you see lines on the test page then the issue is with the cartridge or cartridge contacts. Clean the cartridge and cartridge contacts inside the printer.
rRemove both the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth. Gently wipe the contacts, from the top to the bottom.
Reinsert the cartridge and print. If the issue issue persists replace cartridge(s).
If you do not see lines on the test page. Place the same test page on the scanner glass and make a color copy. If the lines are on the copied Image the issue is with the scanner glass.
clean the scanner glass :
Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. If the output is a full/half-black page, or has vertical black lines, the product needs service or contact HP for in warranty replacement.
Thank you .
Silan
Dec 20, 2007 | HP Photosmart C3180 All-In-One InkJet...
Picture on screen wont stay on
could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components.
Mar 26, 2006 | Sony KV-35S42 35" TV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
99 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
