Question about Paintball Tippmann U.S Army Alpha Tactical Mod Kit
Paintball gun problem
Wut would cause the co2 to empty out the barrel of an alpha black paintball gun if there are no bad orings? it doesnt have egrip. i have taking it apart and all the orings are good. there is nothing wrong with my tanks. i dont know wut to do.
    Novelist:
    Scholar:
  • 111 Answers
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
My paintball wont stop shooting but it has nothing to do with the co2 tank help?
The sear is not catching the bolt and resetting it properly. Or, there is not enough air pressure to push the bolt back to its original position. I would take it to a gunsmith. Parts fly out of a Tippmann if you open it up.
Jun 16, 2014 | Tippmann 98 Custom Act Paintball Gun
In Paintballing what is the difference between nitrogen (N2) and CO2 tanks?
CO2 tanks are composed of liquid carbon dioxide and are used for many scenario and recreation players. When the trigger is pulled, the liquid CO2 is converted to a gas, and this expansion of gas propels the paintball forward at 800-850 psi. CO2 tanks do not work as well in colder weather or for fully automatic paintball guns
Jan 17, 2013 | Sport & Outdoor - Others
This a genesis lethal threat paintball gun I just got it and I am new to paintball what size paintball do I get for my gun please get back to me as soon as possible thank you
First off do you have a hopper and an air tank or co2 tank with air or co2 in it. If no get those things and fill your tank at a local paintball field. If yes your gun takes a .68 caliber paintball. That's really any paintball that you can buy at Walmart or sports authority.
Dec 01, 2012 | Toys
I was playing today and my 98 custom just started leaking CO2 from all the cracks it froze up and ice started coming out of the barrel. what happened and how can i fix it??
your tank loosened up, the co2 freezes the rubber seals they will have to be replaced, you can order a repair kit from the website, change out all the rubber seals on the gun and your co2 tank
Feb 17, 2011 | Tippmann 98 Custom Act Paintball Gun
Inconsistent velocity, and my velocity adjuster doesn't seem to be working
This is caused when a gun needs cleaning and-or O-rings are worn.
Tear down the gun and clean the lube with the special paintball gun oils
and reassemble. See if it is better. CO2 is terrible for paintball guns.
Go with HPA (High Pressure Air, aka Nitrogen) and this will help.
Feb 16, 2011 | Tippmann 98 Custom Act Paintball Gun
When i screw my tank on the CO2 goes right through the gun and out the barrel
**** it and that should stop.
If that persists make sure you have cleaned the marker and used a good paintball oil to lubricate the internals.
At the next level you could have a o-ring that's old, brittle, broken and now is leaking by. Your local airsmith should be able to provide the necessary part(s) or fix it in short order for you.
8^)
Nov 07, 2010 | Tippmann 98 Custom Act Paintball Gun
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Took it apart and don't know how to reassemble
How To reassemble an Army alpha black paintball gun.
Apr 23, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball Tippmann U.S Army Alpha Tactical Mod Kit Logo
228 people viewed this question
Top Paintball Sport & Outdoor - Others Experts
Are you a Paintball Sport and Outdoor - Other Expert? Answer questions, earn points and help others
