Question about Whirlpool Duet GHW9150P Front Load Washer
F21 keeps on flashing???????????????????????????
  • 299 Answers
This error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
Posted on Apr 30, 2010
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Bocsh 1400 express f21 keeps flashing
This Bosch looks like a Kenmore HE2, and may be made by the same manufacturer.
In the Kenmore HE2 manual it states:
"F" Variables [F4 to F16] (Electrical problem)
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call for service.
If it's not working still, try asking advice at RepairClinic.com . They have helped me in the past, and they have parts too.
May 29, 2014 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
I read some of the posts from people who had the same problem I'm having but after following the steps suggested, mine is still not right... My problem is this.. It keeps flashing f21. I know thats a...
hELLO THERE:
OUT OF CURIOSITY DID YOU REMOVE THE PUMP AND TAKE IT APART AND CLEAN THE IMPELLERS INSIDE OF IT THEY HAVE A TENDENCY OF CLOGGING UP AND EVEN BREAKING SOME OF THE IMPELLER RIBS ON IT
PLEASE KEEP ME POSTED ON THIS OK
BEST REGARDS MIKE
Sep 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have a front loading Whirlpool washing machine.. It keeps flashing F21 what does this mean??
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Washing Machines
My washer keeps flashing f21 and no matter what I do it doesn't seem to work.
Hi
f21 is long drain, failed to drain in 8 mins.If unit did actually successfully drain normally then pressure sw is likely the problem.
1. did pump come on? if no replace pump
2. is unit draining at normal rate? no then clean pump.
if yes on both replace pressure sw.
to second poster if getting suds error when using HE then you likely are using to much detergent. If avail run a clean washer cycle.
or normal cycle with bleach or fabric softner, no clothes..
please rate my suggestion..
May 21, 2009 | Washing Machines
The F21 signal keeps flashing.
f21 is long drain, failed to drain in 8 mins. f27 is overfill, overfill contacts on pressure sw closed. If unit did actually successfully drain normally then pressure sw is likely the problem.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops in the middle and flashes F21?
Hi and welcome to FixYa,
An F21 error code indicate drain problem. Might you want to inspect/clean the drain system from the filter to catch basin to impeller, pump/valve and drain hose. To do this, the bottom/kick panel ahs to be removed. A bit of a messy job so pls be prepared with paper towels and other absorbent materials.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
