Question about Huffy Disney Princess 16 in. Girls Bicycle
This bick sucks and you have to have an
This bike sucks and you have to have an engineering degree to put it together. brakes? I am trying to adjust the brakes. Everytime I press the brake handle the brakes engage but the brake shoe on the right side doesn't spring back up. It stays against the rim.
  • 632 Answers
That's fine as long as the wheel spins freely and not stopping the wheel from turning. You can loosen the nuts a bit so it would have some play. If it does affect the wheel from freely turning then you've set the tension to much. It's the same concept with automotive brakes using a floating caliper, one side will release more than the other although not hindering it's operation.
Posted on Apr 30, 2010
How do you put it together?
No instructions?
A wheel at each end, the one with the cog at the back. Head stock and handlebars at the front, and saddle at the back end. Connect pedals, note they have one on the left and one on the right and are marked as such. One tightens normally clockwise and the other TIGHTENS ANTI-clockwise. Adjust the brakes using the adjuster on the side of the brake mechanism. Check everything for tightness, check brakes and ride.
Nov 15, 2015 | Cycling
How do I assemble a Stowabike City Compact Folding Bike
"Before riding the Stowabike for the first time you have to assemble the the handlebars, front wheel, pedals and the back rack. All the instructions how to exactly put everything together will be delivered with the Stowabike." See more assembly info in the link below, where the above text originated.
Stowabike 20 City Bike Compact Folding Bike
What's most important is the adjustment done once the bike is put together. For safety and proper operation the brakes and derailleurs (shift system) need to be properly adjusted, and sometimes the hub bearings as well. You may want to have a bike shop assemble it, or see if your community has a bike co-op, where you can use their tools and get help.
Feb 04, 2013 | Cycling
How do you unseized clutch plates gl1000 75 sat 10yrs creepy in gear
HiClutch not disengaging
Make sure cable has only a couple of mm play. If unable to adjust at handlebars then adjust at clutch endA quick & dramatic way to unseize clutches is to put front wheel up against a wall or similar, bike at 90 degrees to it, front brake on, with full riders weight on seat, in neutral hold clutch in & handlebars straight, rev her up to 3 - 4000rpm, brace your arms & dump her into 1st gearThe shock will generally free-up even a completely seized clutchThe other option is to strip & clean the clutch plates
Ride Safe
Bike-Doc
Jan 08, 2012 | Honda GL 1000 (K1 Motorcycles
CLutch gl1000 creeps
HiChange to bike oil
Unlikely to have to change the clutch
Ride Safe
Bike-Doc
Jan 07, 2012 | 1975 Honda GL 1000 (K1)
Put rear hub back together
put rear brake together on huffy 26 in cruiser bike
Mar 23, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
With the bike in gear and the clutch engage, the
Clutch discs are stuck, put the bike in gear, not running, pull in the clutch and push the bike back and forth to break the clutches loose. Once they break loose start the engine put the bike in gear, hold the front brake, and slip the clutch a little to remove any built up or stuck crud on the plates.
Mar 10, 2010 | 2000 kawasaki VN 800 Vulcan Classic
Adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Aug 27, 2009 | Mongoose 20-Inch Gravity Games BMX...
Rear brakes misaligned
One side of a center-pull brake can be adjusted by tightening or loosening the cable itself (the side with a screw holding the cable in place)
The other side will have a small screw to adjust the tension on the spring.
Sounds like you need to adjust your spring tension screw.
Give it a full (360-degree) rotation and work the brakes a few times. If the problem is worse, then you need to adjust it the other way. If it's getting better, then you're getting closer.
Make several small adjustments, and work the brakes a few times after each one, and you should be all set.
Jun 16, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
Huffy Disney Princess 16 in. Girls Bicycle Logo
288 people viewed this question
Top Huffy Cycling Experts
 Mikey
Mikey
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
