Question about Carrier Heating & Cooling
Error code #42 fault R01 on carrier air conditioner
I have a Carrier 38QPA21-9 reversre cycle air conditioner in the hose. today A fault R01 and cod #42 is appearing on the screen. What is it and how can I rectify it?
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: trying to find tonnage of air conditioner
2 ton.
Posted on May 12, 2009
  • 439 Answers
SOURCE: Carrier air conditioner will not turn on.
It could be the capacitor, or the relay switch on the main unit. Also, if you have had anyone doing yard work, they could have cut your thermostat wires by accident.
Posted on Jun 23, 2009
  • 24 Answers
SOURCE: icing up air conditioner
check your filter. If its really plugged that would cause to ice up or if its low on refigerant that would also cause to ice up.
Posted on Jun 24, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
CARRIER TRANSICOLD A/C SYSTEM
I can find no A27 fault code for this unit, what is it doing? You can call carrier and ask for the definition, I think they will give it to you, just have the specific model number in hand when you contact them.
Aug 18, 2016 | Carrier Transicold Division Heat/cool...
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Sir, carrier model42QG24-C comeing to off after 5 mint and then on after some time it repeate this cycle again and again. The red led on pcb is blinking regulerly..
More than likely it is cycling on its low pressure control.. It is an automatic reset device but each time it cycles off, the TDR (time delay relay) keeps it from restarting for approximately 5 minutes.
A steady and rhythmic 'heartbeat' on the circuit board typically means 'normal' operation. If it flashes, stops, flashes, stops etc, it would be giving you a fault code telling you what is cycling it off. You have to count the flashes, slow or fast or a combination of slow and fast and look up the fault codes.
Apr 28, 2015 | Carrier Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
What could cause carrier fault code 42 besides bad inducer
Could be several causes.
1. Blockage on piping
2. Water in inducer housing slowing down inducer impeller
3. Condensate trap for furnace clogged up.
4. Inducer motor going bad.
5. Leak in vacuum hoses or not connected.
Welcome To the Best HVAC
Oct 09, 2014 | Carrier Comfort 13 Series 1.5 ton 14.5...
Cf code error of carrier
description: cooling fail action is activated. Action: check compressor operation. turn off main power-restart the unit.
see more: Air Conditioning Fault Codes
Jun 09, 2014 | Carrier 38CKC036 Air Conditioner
Carrier 30GX chiller keeps tripping on ground fault.
You need a megohmeter to test the line voltage wiring AND the compressor.
Apr 28, 2014 | Carrier 38CKC036 Air Conditioner
Fault codes for this carrier unit
consult your instruction manual section troubleshooting for this error codes.
If you do not have go for free download: www.fitness.manualsonline.com
or www. manualsfactory.com or www. retrevo.com
God bless you
May 09, 2012 | Carrier 38CKC060 Air Conditioner
Carrier error 42 on model 58MVP080.... is it the inducer motor or control board?
Low pressure sensor fault. Check dc voltage between white and black cable on plug. Multi V: 1 Vdc = 4 bar up to 5 Vdc = 32 bar
Oct 19, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
450 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
