Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Replace pump - Bissell 8910 ProHeat Clear View Upright Vacuum
  • 20 Answers
Six (6) on board/top screws approx. Two (2) in front near nozzle area and four (4) under water resevoir tank. Engage handle release and lie handle down on floor and take out screws and save (of course) You will need to also unscrew clear water cap from top of on board unit and save and make certain you retain process to put back into position..(cap/spinner/small screen /pin up) Now you have access to the pump/motor, drive belts, etc. Unscrew appropriate screws and detach water lines and note replacement points. from pump near front right area of unit. Good luck!
Posted on Apr 30, 2010
Bissell Proheat Clearview 8905 pump replacement
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vbzb
Jul 09, 2010 | Bissell 1699 ProHeat Clear View Upright...
How to check the location of the pump belt?
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Jun 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Pro heat pump
That is correct; the new pump has a metal pulley, which is more durable.
J
Jun 07, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
7920 ProHeat replace red pulley on the pump
Pulley only comes with the pump. So you have to replace it, 2107181 it will cost about $30
May 03, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat Clearview - Belt and pump keep melting
Is the brush roll turning freely? Is there something binding the pump pulley or belt casuing it to not turn? Was the replacement pump a new one? If you replace these parts again, after doing so, try turning the pump pulley by hand to see if it will turn the brush roll easlly, if it doesn't then there is a problem.
Apr 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
How do you replace the belt? I took off the door and there seems to be no easy way to get it over the lower red wheel.
Mar 26, 2008 | Vacuums
Pump
Check the bottom of the tank and make sure that the seal is on the valve and not sitting in the hole where the tanks sits. At the back, is the top and bottom tight together, or is there a gap, should be no gap. Is the mix valve **** turning easily or is it hanging up? Sometimes the flow indicator cap leaks air and needs to be replaced. To get to the pump, you have to take off the top cover. Look and see if any lines are pinched, if not, then replace the pump, also check the pump belt.
Mar 10, 2008 | Bissell 1699 ProHeat Clear View Upright...
How to replace pump for 7901 bissell pro heat steam cleaner
unplug unit first
take six screws out of housing.
lift of housing.
you can see pump at front of machine.
four screws hold pump in.
make sure all tubes are routed correctly.replace housing,
make sure no tubes are trapped
Jun 04, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
208 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
