Question about Olympus EVOLT E-500 Digital Camera
Flashing shadow area on olympus e500
The word shadow flashes in bottom right corner of viewfinder, same time dark areas of picture flash white and black. I thought this was a WB issue but unable to fix. any suggestions on how to stop this from happening?
  • mejump Apr 26, 2008
    I have the same problem the shadow flashing at the lower right corner.
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Posted on May 02, 2008
Pictures being viewed are flashing in some areas of the photo
You're seeing blown-out highlights. Those are the areas of your pictures that have lost all detail by going pure white. In general this is considered a bad thing. The correct fix is to reduce the exposure to bring back the details. This may lose details in the shadows, but that is generally preferrable to losing details in the highlights. After all, we expect not to be able to see things in the dark. Of course, this is only a warning; the camera doesn't know what kind of effects you're trying for.
That was the long answer. The short answer is: press up/down on the multiselector to cycle through the different views of your picture.
Sep 04, 2010 | Nikon D60 Digital Camera
My fisheye pictures don't come out perfectly circular anymore... on the bottom right corner of all the pictures is a black part that looks like a shadow. what is wrong with it?
Sounds like you have a light leak. At the film plane of your camera the image from the lens is upside down and laterally reversed, so the light leak is at the top left of the film when it's in the camera. If you're shooting for prints look at the strips of negatives. If the edges of the film are affected as well as the picture area then the light leak is at the back. If it's just the picture area then the light leak is through the film gate. If you hold a strip of negatives in the camera with the emulsion towards the lens and the picture upside down and then line up the picture with the film gate this should point to the problem area. All this assumes that your finger wasn't in front of the lens... :-)
Nov 29, 2009 | Lomo Fisheye 35mm Film Camera
Black flashing in bright areas of image when viewing
This is a tool to tell you where your photo is under or overexposed. If you use the up/down button to scroll through the display options (file info, shutter speed, filename...etc) will take you to the view where the highlights are shadowed or whited out. One of the views has no data or highlighting. Just leave the view there.
Aug 29, 2009 | Nikon D40x Digital Camera
Nikon D80. It worked fine until recently (maybe after I took pictures during whale-watching in a heavy rain and camera got wet). Now the view in the viewfinder is kind of greyish and blurry. Focus area...
Seems like your problem on greyish/blurry viewfinder is caused by the camera getting water logged. Get your cam cleaned by Nikon.
The flashing red light usually happens if you have this indicator set in the camera. This may not necessarily be an error.. just a setting that you have put in place in your menu.
Jul 10, 2009 | Nikon D40x Digital Camera
Nikon coolpix 4800 - built-in flash may need to be replaced
I have the same camera and have had the lens cover get stuck and it will leave the dark shadow in the pictures like you describe. It doesn't always happen, but when it does I just gently push the lens cover all the way open with my finger.
Mar 05, 2009 | Nikon Coolpix 4800 Digital Camera
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
Shadow's
try to reset camera or you may need to brighten the exposure
Sep 17, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus E300
Hello Kate, See if you can find an internet cafe. I was reading the white balance section of your manual and there is nothing that stops your camera from taking pictures if the white balance is off. Turn your camera off, remove your batteries for about 30 seconds and let it reset to default. Then try inserting the batteries and see if this helps. I wouldn't mind sending you this manual if you can provide an email address. Or a link to go to is: www.olympus.com, then select americas, then select support, then select your camera, then download your manual in PDF format. I wouldn't want your vacation ruined either.
Aug 11, 2008 | Olympus EVOLT E-300 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Shadow across photo
Shadows, especially circular shadows, are pretty common with the pop-up flash. What you are seeing is actually the shadow cast by the end of the lens. This happens especially on wider angle shots.
The solution is to find a way to get the lens out of the way of the flash. You can get an external flash, like a 430ex or 580ex, which elevates the flash far above the lens. That is an expensive option so first you might try making a diffuser for your pop up flash, which softens the source of light and helps eliminate some shadows:
http://www.diyphotography.net/diy-built-in-pop-up-flash-diffuser
http://www.flickr.com/photos/natuurplaat/10362363/
Dec 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
269 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
