Question about GE GSH22SGRSS Side by Side Refrigerator
My GSH22SGRBSS which was manufactured in 2004 has
My GE side-by-side refrigerator (model GSH22SGRBSS) which was manufactured in 2004 has a defrosting problem. Is there a repair manual or photos on the web that will show me how disassemble it to get to the defrosting parts?
  • KingSlav Apr 30, 2010
    This is very helpful. Does GE (or an outside vendor) publish an illustrated service manual for this refrigerator?
  • Anonymous Mar 21, 2014
    what year was it manufactured
  • GE Master
  • 1,606 Answers
Extremly rare for a motherboard to cause a defrost problem ! Most of the time , it is only the a bad heater . However , to check the system ,
pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off .
Posted on Apr 30, 2010
  • Mike Smith
    Mike Smith May 01, 2010
    Ge refrig manuals are printed for technicians and tech school attendees . I know of no outside manuals available . You do have a tech sheet located somewhere on the refrig , but mainly electrical diagrams .
    Guru:
  • 1,524 Answers
You have a bad motherboard.
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
Defroster not working
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
Apr 07, 2013 | GE Monogram Side by Side Refrigerator
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Defroster cycle stuck
Unfortunately GE has been having a problem with the main mother boards on your model refer, the mother board controls the defrost cycle and there is not reset for it, you may have a bad board.
Mar 17, 2009 | GE GSS20IEM Side by Side Refrigerator
Freezer freezing over refrigerator not cold
The refrigerator is not defrosting. The elements, defrost cycle or wiring to the elements are defective. Is you refrigerator digital controled or manual switches for temperature?
Let me know so I will be able to help you. JT
Feb 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side freezer not defrosting (model GSS25SGBRSS)
there are only like two different ones that the manufacture use. one has four wires to it and the other i thinlk has three. All you need is the k=make and the model number of your refrigerator and the people at the parts house should be able to help you.
Jan 21, 2009 | GE GSS25SGRSS Side by Side Refrigerator
GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Apr 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22SGRSS Side by Side Refrigerator Logo
500 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
