Question about HP NB199UA Pavilion Notebook
Laptop only charges half way
When I plug in my hp pavilion laptop, it will only charge to 53%, then it stops charging.
  • HP Master
  • 4,924 Answers
This is a matter of battery ..probably it is a modular one ..and it has some modules that has expired ..and the software that display and measure the battery status..is st to see a certain value in the batteries voltage and amperage to display full... so if one of the modules will not charge anymore..it will work ..but it is practically like a half full battery ..the way to fix is to buy another one ..compatible..
be sure you formatt it right when you first use it ...follow the instructions or make a search on google about formatting the li-based batteries cause this is the main cause for this to happen ..
Posted on Apr 30, 2010
Tip
HP Pavilion dv9000 battery tips Your new HP Pavilion dv9000 laptop battery comes...
DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Chemistry : Li-ion
Voltage : 14.8V
Capacity : 4400mAh
Corlor : Black
Original Price: US $85.63
Special Price: US $65.63
warranty.jpg * 1.One year warranty, 30 days Money Back.
* 2.Brand new, 100% Q.C. of every battery.
* 3. Highest quality Japanese battery cells.
* 4. Guaranteed to meet original specifications.
* 5. 100% secure and safe.
  • Shipping: Our laptop batteries are shipped by USPS.
    The battery have a good compatibility with many original laptop batteries for many laptops, even diffenent brands.
  • Descriptions of Hp DV9000 DV9700 DV9600 HSTNN-IB33 Battery 1. 100% new high quality Replacement DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Compatible Li-ion Batteries.
    2. This Hp DV9000 DV9700 DV9600 HSTNN-IB33 battery can be used for the other models and battery part No.
    3. 30-Day Money Back,1 Year Extended Warranty for Hp DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery.
    4. Great After-sales Service Department for laptop battery, fast respond to your request!
    5. Fast delivery if you order the Hp laptop battery.
    6. Need any assistance on DV9000 DV9700 DV9600 HSTNN-IB33 Laptop Battery, please feel free to email us!
  • on Jan 27, 2010 | Computers & Internet
    Problem with HP dv3 power cables.
    Sounds like the charging board may be malfunctioning/shorting out inside the laptop itself causing these ac adapter failures.You really need to have it looked at before other it causes you motherboard to fail or any components connected to it.The power jack may be shorting as well which is attached to the motherboard
    Dec 17, 2011 | HP Pavilion Dv3-1075us Notebook
    My laptop is not charging. it says 0% available (plugged in, not charging) plz help i have a stock hp pavilion dv5
    Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
    Jun 25, 2011 | HP Pavilion dv5-1138nr Notebook
    I am Using HP dv 4 I have a problem that when i plugin the ac adopter it shows that it is plugeed in but not charging
    Shut down the system. Take the battery off. Leave it for half an hour. Re-connect the battery and plug-in. Charging stops if the processor fan is being blocked. Use surfaces like table to use ur laptop. Don't use it on bed.
    If problem persists contact service centre.
    Apr 16, 2010 | HP Pavilion dv4000 Notebook
    Is this hp pavilion dv1000 battery a cheap one?
    From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
    Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
    Rating: rate4.gif
    Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
    8800 mAh 11.10V C $ 79.69
    Availability: In stock
    Notes for charging Hp Pavilion dv1000 Series battery :
    1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
    2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
    3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
    4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
    5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
    6. It is normal for HP laptop battery to become warm during charging and discharging.
    7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
    Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    HP DV6000 Won't Charge
    The charging process is suspended temporarily because the battery has overheated. My brand new DV5 (3 weeks old) does the same, because it's really hot here.
    Turn the laptop off and the battery should charge. Also, when you do not need the battery and are running off the mains, remove it from the laptop. Keeping a battery at 100% wears it 4 times faster than doing regular charge/discharge cycles.
    Jul 02, 2009 | HP Pavilion dv6000t Notebook
    HP NB199UA Pavilion Notebook Logo
    1,224 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
