Question about Nikon 28-70mm F2.8 ED-IF AFS Lens
Nikon AF-S Nikkor 28-70mm f/2.8D First, the
Nikon AF-S Nikkor 28-70mm f/2.8D First, the aperture diaphragm is stuck at small aperture setting and aperture diaphragm blades do not open up when you adjust the aperture ring. Second, the AF-S motor makes squeaking noise when you start the autofocus but the noise will go away after some use. The autofocus functions well but because the aperture is stuck at small setting, there is not enough light going through the lens, thus the camera can not lock the focus
SOURCE: Problem with the Nikkor AF-S DX 55-200 zoom lens.
I just had the same exact problem! However, in my case I was finishing up a photo shoot at work, went to switch lenses, and when I picked up my 55-200mm zoom lens, the tip of it fell off!! I was able to put it back into the end of the lens, but now I am having the same autofocus problem and sound effect. I think it is because it is off track inside the lens. But I have only had mine for 5 months! I'm preparing to send it to Nikon for warrenty repair.
Posted on Apr 25, 2008
jcdill
  • 121 Answers
SOURCE: Sigma AF 24-70mm f/2.8 EX DG macro (Canon) or Canon EF 28-70mm f/
I have the Canon 24-70 f2.8 L lens, and there's no way you could ever get me to exchange it for a sigma lens. There's no question that this is a very excellent lens.
Why are you considering the sigma lens?
Posted on Jan 26, 2009
  • 13 Answers
SOURCE: Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Posted on Jun 12, 2009
  • 146 Answers
SOURCE: Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Posted on Jul 04, 2009
ftw1952
  • 10319 Answers
SOURCE: My Nikkor AF-S DX VR 18-200 stopped focusing
the lens internally has a electrical circuit ribbon that contracts when you adjust the lens everytime. They are prone to get crease causing a short in the auto mode.b It can be checked and replaced bt most camera technicians
Posted on Nov 06, 2010
Nikon 3100 won't take pictures using prime lens
Then do so. Turn the aperture ring to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Dec 02, 2013 | Nikon 50mm f/1.8 AF Nikkor Lens
Diaphragm stuck
It's serious enough that you will not be able to fix it yourself. You should send your lens to Nikon for a repair estimate. You will find information on the Nikon USA website regarding where your closest Nikon Repair Depot is located and return procedures.
May 29, 2013 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
I can't get the minimum aperture lock to lock on my 70-210 f/4-5.6 AF Nikkor
What happens if you simply turn the aperture ring to its smallest setting (largest f/number)? Does it lock then?
Jan 26, 2013 | Nikon AF 70-210mm f/4-5.6D Zoom-Nikkor...
Aperture ring won't turn
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
Sep 30, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
When i attatch my 70-300 lens i get a flashing FEE in the box,the book says to set the minimum aperture how do i do this please.
Thanks for the additional info.
First, an apology: I misread the lens description, sorry. If you have the "AF 70-300mm f/4-5.6 ED Nikkor" then the lens DOES have an aperture ring at the rear of the lens. If this is the case, then your D50 is compatible and all you need to do is turn the aperture ring on the lens until it's at the minimum f32 setting. The "FEE" message on your D50 should then vanish. When set this way, you control the aperture setting on the lens via the camera body controls. The command wheel alone adjusts the aperture when in Aperture Priority mode, and in Manual or Shutter Priority modes you need to first press the " /-" button behind and to the right of the shutter release before using the command wheel. There's even a handy little printed icon of a lens diaphragm to remind you of the secondary function of this button.
If your lens model is the "Nikon 70-300mm f/4-5.6G" then like a G lenses it lacks an aperture ring and so can only be controlled by Nikon bodies which operate the aperture from the body alone, like yours. So if you're getting the FEE error with a G lens then there's most likely a common fault which occurs with Nikon bodies with a small switch beside the lens mount. In the picture (courtesy and copyright of Digital Photography Review), the switch is at the 8 o'clock position.
This switch is activated either when a non-G lens aperture ring is turned to the smallest setting or when a G lens is correctly mounted. It is possible for the G lens to be damaged in such a way that the switch doesn't get activated but it's rare. If the switch is broken the camera body will need a repair.
Hope this answers your question, but if not add further comments. If it has answered your problem then please let me know by rating my reply.
Sep 14, 2010 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
May 30, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Repairing 20mm af nikon lens diaphragm lock
I'll offer the same answer I just gave on a D200 question: With the lens off, look at the camera mount area. If you are looking straight at the mount, there is a small tab sticking out at about 7oclock on the outside edge of the mount ring. The tab is spring loaded and may be damaged. You should be able to push the tab toward the base of the camera and it will snap back if functioning properly. If it feels loose or doesn't spring back, then switch that ab controls is not being activated.
Oct 24, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Oct 21, 2006 | Nikon F100 35mm SLR Camera
Nikon 28-70mm F2.8 ED-IF AFS Lens Logo
131 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
