Question about Hitachi 43UWX10B 43" Rear Projection Television
Crack in screen - Hitachi 43UWX10B 43" Rear Projection Television
crack in screen need new protector screen for it
  • ellerocks Mar 25, 2008
    29" tall 38 " wide
    the protector screen is not a smooth screen it has lines or something in it but when u run ur hand over it its not smooth,n i was thinking the same thing just take the screen of but when i was messing around with the crack a lil peice came off n i looked inside n all that you see is a red blue n green lightn the mirror for the t.v is behind it,i dont mean protector screen like on the new modles its the acctual screen itself its just plastic
  • 74 Answers
Call Tritronics at 800-638-3328 for the screen. It must be the original to fit. Order by model number and use a credit card to pay for it. The protector screen is smooth, if that is the cracked one, then you can take it off (with some work) and the picture will look the same.
Posted on Mar 25, 2008
  • 53 Answers
You can buy replacements online. Try www.partstore.com
You can remove the screen yourself, actually, on a lot of these sets, it just means lots of unscrewing to open the cabinet and get it out. If only one layer of your screen is cracked, it will be a lot cheaper. And if only the protective covering is cracked, I'd just throw it away and not worry about replacing it. That sparkly colored effect you see on white colors on the picture? That's the screen protector. Some people remove it for aesthetics.
MY TOSHIBA LCD TV SCREEN IS CRACKED DOES IT HAVE A
Hi Erika,
If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
Oct 03, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
Replace a cracked screen on a pandigital ereader
Been told by Pandigital support that you don't replace broken/cracked screen. They reccomend you buy a new media tablet.
Dec 28, 2010 | Lexerd - Pandigital novel 7" color...
My brother threw the remote at the TV and cracked the screen. I was wondering how expensive it would be to replace the screen. The TV still works fine, and we have no need to buy a new TV anytime soon, so...
The protector screen is $247.79 If the screen behind that is damaged, that one is $147.97 If the last screen is damaged, that one is $495.00
I hope he only damaged the 1st clear screen, known at the screen protector
Dec 28, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
I got a toshiba tv and cracked the screen on it wer do i get a new screen 4 cheap
pigdigger,
I have bad news for you, the total cost for the three screens you will need will be about $290.00. They can be obtained from http://www.encompass.com . Here are the part #s: Fresnel 23311898 $80.00, Lenticular 23311897 $120.00 and Protector 23311863 $90.00.
Installation is straight forward. Generally you have to remove the back top cover with the mirror attached. Then check under the bezel on the front, below the screen, for several screws. Remove the screen and lay it flat on the floor. Remove the screen hold in screws or clips. Remove the screen.
Assemble the new screens. Make sure they are in the correct order. Protector (on outside), Lenticular in the middle and the Fresnel on the inside. You will need to secure the screens together. Black cloth tape works well around the perimeter. Reinstall the screen into the frame and reassemble the unit. This should complete the job.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 29, 2010 | Toshiba TZ50V51 50" Rear Projection...
Need a new screen as my screen is cracked
You can find a replacement at http://www.encompass.com . There are three parts to the screen (protector, screen & fresnel) and you will need all three if they are all cracked which is most likely. Total cost about $200.00 plus shipping. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 15, 2010 | Toshiba TP43H95 43" Rear Projection...
I just broke the diamond shield on my 2002 mistubishi. I need someone to replace it.
these tvs have 3 screens, 2 functonal, and the 3rd is just a screen protector. mitsubishi makes them so you can remove the protector to eliminate glare if you want, and its customer removable. if this is the only one that cracked, remove it and you will actually have a better picture. you just need a small flat head screwdriver. pry of the little plastic pieces at the top and bottom (some are on sides) that hold the screen in. its just held in on 2 sides, and then you flex it to get it out. if it cracked into the 2 screens behind the protector, you've got bigger issues and the repair could get expensive. contact your local mits service center for quotes, but the screens are atleast 100 each, just for parts. let me know if i can be of further assistance.
Jun 06, 2010 | Mitsubishi WS-48413 48" Rear Projection...
Cracked screen cover on Kodak camera
screen protectors are only plastic covers that protects the screen from scratches and such.
It is not possible to buy a new LCD screen.
Since the camera is now Out of Warranty a repair will cost 48 pounds with KODAK.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 13, 2010 | Kodak EasyShare M1033 Digital Camera
Cracked Screen Protector
what is the model number for you set. is it a hd52w56 or something like that. on that model it is called the super sheild. is the inner screens damaged.. if just the outer screen that runs 200 or more. i have seen people just replace the plexiglass on it. the inner screens run about 250
Nov 09, 2008 | Televison & Video
My screen on my rca 61130 has cracked i ve removed the screen protector and need a NEW SCREEN can it be replaced
yes it can be replaced.calling a technician is much advisable as fitting the new screen is not very easy as it should be allighned as the old broken screen was before.if there is a slight difference in the fitting you will not be able to see the clear picture.
thanks.
Oct 13, 2008 | Televison & Video
Cracked plasma tv screen
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it. http://www.tv-armor.com
Mike
Oct 27, 2007 | NEC - 42" Commercial Plasma Screen ****(no...
Hitachi 43UWX10B 43" Rear Projection Television Logo
127 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
