Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I have a Kodak Easy Share 5300. Just changed both
I have a Kodak Easy Share 5300. Just changed both the black and color cartridges but the color still sucks! What do I do?
    President:
  • 524 Answers
  1. Check that your color cartridge/toner is not empty or blocked.
    This is the least likely cause of the problem, but an important check to make. Most color printer drivers and/or software provide functions to verify alignment and color output. Consult your manual or open your printer driver by clicking Start : Settings : Printers and right-click on your printer's icon and select Properties. 'Browse' the Properties dialog for options that perform system checks.
  2. Look for a 'Print only Black and White' option.
    Open your printer driver's Properties dialog (see above) and look for a color option that uses black only. Uncheck it or select an option that enables color. Some color printers have different resolutions for color and black-and-white (usually higher resolution in black-and-white). Some applications (not Origin) will force a printer to use a quality mode that affects this option, and if the resolution is forced to its highest the color output may be disabled.
  3. Enable gray scale printing.
    Some combinations of printers and operating system versions can lead to a miscommunication between Origin and a printer driver. Under these circumstances, Origin may 'think' it is dealing with a black-and-white printer when it is actually using a color printer. Beginning with 6.1, the Origin Print dialog displayed one of two messages depending on the print capabilities read by Origin:
    1. Enable color as gray scale
      This check box displays for color printers
    2. Use simplified colors
      This check box displays for black-and-white printers
    If you are seeing the first checkbox and you are using a color printer, then checking the box should tell Origin to send all color information and let the printer handle any conversions that may come up. In earlier versions of Origin there was a rather cryptic "Print color on black and white printers" checkbox which did the same thing.
Posted on Apr 30, 2010
My KodakEasy Share 5300 will not print in black.
92b8b47.jpgThe Kodak AiO printers 5000 series and ESP series PRINTHEADs has orange protective cap that need to be remove to fit on the printer carriage. For the ink cartridges 7b91cbc.jpgthere is also a orange protective cap.
Issue that its not printing black and deep clean and removing the printhead and reinstalling the printhead (reseating printhead) is already done and still no black when printing. The printhead should be replace. For futher assistance call 1 800 421 6699 Kodak AiO printer support line
Nov 16, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5500 AIO easy share printer will not print black ink.
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My Kodak Easy Share 5300 doesn't print black ink
You need a new printhead. Call Kodak and they will send you one.
Jan 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Changed ink cartridges Kodak 5300 print blurry/missing letters
I called Kodak and they are sending me a new printer head at no charge! Can't get any better then that. Man I talked to was very nice, knowledgeable and polite.
Dec 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak Easy Share 5100 will not print after I changed black cartridge
Press copy and photo at the same time and print a demo sheet. Look at the eyes of the two kids in the picture, if they look like zombies, your printhead is clogged. try cleaning the printhead and print the demo again. If it's the same, you need a new printhead. Call Kodak.
Oct 08, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5300....Problem:
I cannot get the printer to work on the USB cable. I have tried about everything. Seems that the drivers are there but there is something else wrong. Now what?
Nov 26, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
274 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
