Question about Innovage Touch-panel Phone 1502084
Volume issues I am having a hard time getting the volume up. I accidentally turned down the volume and now can not get it back up. It is only like this for the music, though. I followed the directions given in the booklet and it doesn't work. Please help me.
  • pkeyes40 May 11, 2010
    you got a booklet? what a bargain!
  • 32 Answers
Press HANDS FREE once, then press DELETE to select the LOUDNESS (1-4). then press HANDS FREE to confirmsetting. press DELETE to exit. you might have to do this in "HOLD" mode to get it to raise the volume on the hold music.
hope it helps.
tammy
Posted on Aug 12, 2008
SOURCE:
I cant get into my tablet forgot password
That was silly wasn't it. If you can't remember a simple 4 digit code or a funky pattern don't set one.
You will have to Factory, or Hard Reset it, which scrubs it clean.
Power down. Press and hold the Volume Up and Power button until the Recovery Console appears. Back up and Reset.
Don't do it again :>)
Jan 02, 2017 | Tablets & eReaders
There is no sound when I receive phone calls?
Perhaps you have accidentally pushed the volume button and turned down the sound.
Many of the cell phones have a volume button on the side, and whilst holding the cell phone with your hand, your hand pressed on the volume button and holds it down accidentally.
Find the volume button and see if it is turned down.
Remember, most of these have one button for both the incoming call volume and also the speaking and listening volume all at once.
You have to adjust both volumes with the same button depending on what your phone it doing when you press it.
God bless your efforts,.
May 16, 2016 | RIM BlackBerry Cell Phones
Volume turns down by itself until it says VOLMIN
The quick fix is to unscrew the cover and also remove the faceplate. There is a very small brown ribbon connecting to a slot where It is labeled in small lettering "vol + / vol -". That ribbon will disconnect the front volume touch panel. That has solved my issue. I own the Samsung Home theatre with the vacuum tubes.
Feb 14, 2014 | Samsung Audio Players & Recorders
My Concord shuts down multiple times a day
May have a low memory issue going on.. Turn off any unnecessary features, and try pulling the battery out and putting it back in.. If that doesn't help, you my have to do a hard reset and restore it back to its factory condition... Here are the instructions to reset your phone: To perform a hard reset using hardware keys, follow these steps: Power off the device. Press and hold Volume Down key. Press and hold Power key until the Android and Triangle logo appears on screen. Let go of buttons once the logo appears. Press the device Home key. When the Factory Data Reset option appears, use the Volume keys to scroll to and select it with the Menu key. When Wipe data? appears, use the Volume keys to highlight Yes, and select it with the Menu key. Once Data Wipe Complete appears, use the Volume keys to highlight Reboot System Now and select it with the Menu key. Hope this helps...
Mar 05, 2013 | T-Mobile Concord
My phone ringer accidentally got turned off how do I get it back on panasonic PQLV30054ZAS
For a KX-T7633 press the up arrow to increase the ringer volume (up or down arrow adjusts the volume). Some phones (KX-T7625) also have a ringer ON/OFF switch on the back of the unit.
Mar 01, 2011 | Panasonic KX-T7633 Corded Phone
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
Dear Experts, I have issue with my HTC touch 3g. With no reason my TouchFlo has disappeared and now I have only the option "tap here to launch TouchFLO" but doing that I am getting the same screen again...
you will lose everything on your phone but this is the only way to get it back . IF! there is no hardware type problem that is causing this.
1. With the device turned on, press and hold the VOLUME DOWN and ENTER buttons, then press the RESET button with the stylus tip.
2. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
3. Release the VOLUME DOWN and ENTER buttons, then press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Aug 08, 2010 | HTC Touch™ 3G Cell Phone
Change language from german to english
If you do a hard reset it will go back to factory default settings.
With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
Release the VOLUME UP and VOLUME DOWN buttons, press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Jun 11, 2010 | HTC Touch HD Smartphone
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
Volume Issue with CD Player by Durabrand.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
Mar 24, 2008 | Audio Players & Recorders
Innovage Touch-panel Phone 1502084 Logo
96 people viewed this question
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Damen Wong
Damen Wong
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
