Question about Kitchen Ranges
Error 43Our Bosch range will not open after setting to self clean
Our Bosch range will not open. I set the range to self clean and received error message 43 and the door locked. I turned off the error message, but now the range will not open. Model # HGS 7282 UC/01
  • 1,998 Answers
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Posted on Apr 30, 2010
I have Bosch self cleaning oven, door will nit open and control panel says error 43 what do I do?
SOURCE: Error 43Our Bosch range will not open after setting to self clean
Error 43 on Bosch range how can open the oven door
Mar 26, 2018 | Bosch Ovens
Bosch gas range error code F11
Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it.
If the F11 is still there most likely it's the control panel.
God bless you
Feb 01, 2013 | Bosch Evolution 500 HGS5053UC 30"...
I'm getting an E1 f5 error code and my oven won't light
The F5-E1 error code means that their is a problem with the switch on the self clean door latch...it (the switch) is telling the control board that the door is locked even though it may be open so it will not let the oven come on
GENE
Nov 14, 2011 | Whirlpool SF325 Gas Kitchen Range
Bosch HWS will not start up . ie no flame. no nothing. Water pressure seems ok. Have removed filter and cleaned
Problems can range from bad check valve to crossover in shower faucet, to bad PC board to tripped breaker. That's a pretty broad range.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Open link below for a few self-help remedies and many resources; contact service technician and contact Bosch, read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual and suggested by service technician.
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 29, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch convection oven in self clean mode, am getting an error code of 41
Hi, I am getting the same error today. Did it ever clear up? Were you able to open the door eventually?
Jan 24, 2010 | Bosch Evolution Pro-Style 700 HDS7282U...
Error when self-cleaning - oven locked
Here is the error code and things to check on your oven.
Error Code: F41 Cause: Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check that the solder joints in header P24 on the power board are not broken. 5. Check P10 connector and check if latch motor wire is
Regards
Alan Hood
ami-man
Dec 04, 2009 | Bosch HES5042US / HES5052US Electric...
I tried to set my self-cleaning on my Electric Kenmore range model # 66592012100 and I get the error message E1 F5 I can't set my oven to self-clean just my luck
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Bosch evolution range door won't lock for sef cleaning
You are correct. If the door does not lock, the self-clean function will not activate.
Spray some WD40 into the lock mechanism and let it sit over night. Then try it again.
Feb 10, 2009 | Bosch Evolution Pro-Style 700 HDS7282U...
My oven flased an F9 error....
The solution to this issue is to finish running the self cleaning feature to this oven, Shutting off the oven or opening the door before the self cleaning feature has completely run will send a F9 error from the safety co0ntrol unit feature built in to the system bios of the control circuit, You will need to close the oven and set the option self cleaning to run now. if your error message prevents you from taking these steps you will need to unplug the oven from the wall socket and let it sit for an hour to reset the screen and then run the self cleaning feature all the way trough, it will shut down on its own when the self cleaning cycle has completed
Oct 24, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
708 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
