Question about Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
Power head turns on and works the power that turns vacum on not
The motor for suction does nothing. I took foam filter out and cleaned it but do not know how to do anthing with button that says something about cleaning filter
    Sergeant:
    Champion:
  • Bissell Expert
  • 357 Answers
If the suction motor doesn't come on but the brush motor does, you have a bad vac motor. If neither motor runs, it's probably a cord problem. Most parts for these are not available anymore.
Posted on May 01, 2010
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Bissell pro heat
You have something stuck in the hose or you have a filter that you haven't yet cleaned . You will need to remove the hose at it's mount and strech it out , if alls well there, then look for a small foam filter hiding on the machine going to the motor area most people miss this one and burn up the machine. run without bag outside to check.
Sep 06, 2012 | Bissell 8910 ProHeat Clear View Upright...
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
My hose no longer works no suction buth the vacuume still works how do i fix I checked the hose checked the filters nothing works to get my hose so it has suction.
Check the following after unplugging the power cord from the outlet.
- Check for suction at the back of the unit, after removing the hose where it attaches to the back of the vacuum. If there is NO suction, the machine will need to be taken to a local Service Center for inspection.
If there IS suction at the back of the machine with the hose removed, please check the following:
Unplug the unit from the outlet.
- Check the Pre and Post-Motor filters for debris. Dirty filters can restrict airflow. The pre-motor foam filter is square and located in a pull out tray underneath the dirt cup. The foam filter may be hand washed in cold water with mild detergent. Reinstall the filter when it is completely dry. The post-motor HEPA Media filter is rectangular and located on the side of the machine. Note: The white HEPA Media Post-Motor Filter is not washable.
- Ensure the dirt cup is empty.
- Check the upper tank for build up or clogs.
- Twist the inner cyclone to the left and pull down
- Wipe the inside of the upper tank and separator plate with a
damp cloth moistened with water or mild cleaning detergent.
- Once the inner cyclone is dry, lock back into the machine by
pushing up and turning to the right.
- Put the dirt cup back in
- Check for good suction at the end of the upholstery hose. If there is good suction, make sure the hose is firmly connected to the lower hose on the back of the vacuum. If there is no suction at the end of the hose, check the hose for splits, cracks or clogs.
- Make sure the brush is rotating. If it is not, remove the access plate and examine the brush, and belt for damage. The access panel can be removed by lifting the 4 tabs located at the bottom of your machine. Lift tab 1 then 2-4 tabs to remove the access panel.
CLEARING CLOGS
- Detach the upper hose from the machine. Insert a broomstick into the hose to push any obstruction through to the opposite end.
- Remove the screw from the left side of the lower hose on the back of the unit, and straighten this section of hose by pulling it down or lay the unit out flat, and roll the unit on its side with the lower house towards the top side. Look through the hose for any obstructions. Push a broom stick through the lower hose to unclog.
Aug 12, 2010 | Bissell Upright Vacuum - The Pet Hair...
Dyson DC07 Vacume cleaner trips on thermal after 10 min motor not excesive hot resets after 15 min has been doing this for the last 3 mths. Could it be faulty thermal or motor overheat how can I check...
first, check both filters on that unit. the premotor filter on the side, and the hepa filter underneath the canister. if those filters are clean move through the suction channel and look for a clog or obstruction. also make sure the canister is clean. I have never seen the thermal go bad on those machines (not saying it cant happen though). it sounds like the filters are dirty or you have a clog. its also a good idea to change the pre motor filter if its older than a yr. the foam is fine but the white material behind the foam gets clogged frequently. let me know if you have any other questions and if this doesnt fix the problem.
Jan 06, 2010 | Dyson DC07 All Floors Bagless Upright...
Dyson vacuum suction loss
clean it out
check all the filters
I think it has a foam filter as well as the filterless design
clean and lubricate the motor
make sure it is not leaking and sucking in air from somewhere else
Jan 02, 2010 | Dyson DC11 All Floors Bagless Canister...
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum Logo
94 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
