Question about Husqvarna 28cc Gas Line Trimmer
Cant get spring back in place for throttle trigger
2 Suggested Answers
slohry
  • 87 Answers
SOURCE: husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Posted on Apr 10, 2009
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
Putting handle back together it was leaky , cant find place for spring?
not sure but i am sure that its job was to push the trigger/throttle back in place so this should help you figure it out, more than likely behind the trigger look for a small protruding post/groove that would keep the spring in place--- you have pics to show now? that would help--- good luck questions just ask
Mar 30, 2013 | Powerwasher 80012 Universal Pressure...
Throttle trigger does not retract
Item 6 on the plan are spring washers, i cannot see any other tension springs that control the retraction of the trigger. Hope this helps you.3_2_2013_11_20_49_pm.jpg
Jan 06, 2013 | Stihl BR400 Backpack Leaf Blower
How do I reconnect ,my throttle trigger for ms 260
remove the top cover on the handle, there is a screw in the bottom of the handle end. put the on off switch in the choke position all the way down, connect rod to throttle on carburetor then slip it into the hole in the trigger. replace operator presence lever making sure the spring is in the notch on the side of it, while holding it in place reinstall the top cover.
Jun 13, 2012 | Stihl 024 026 Ms240 Ms260 Throttle Trigger
I think you call it the throttle trigger i dropped and it broke i cant give it the gas
You need to rplace the trigger, if this is a 350, start by removing the throttle lock on the top of the back handle, gently open up the slot where the latch fits, at the same time pry the rear end of the latch up, it will pop up at the back, once up pull the latch toward the back of the saw and away, now knock out the roll pin that the trigger pivots on, once out pull the trigger slightly back and down, it will just pull away, replace with a new trigger and re fit the the roll pin, push the throttle lock latch back into the tank and push the back end down to lock it into the tank, make sure the spring locates into the latch. adw1_11.jpg
Sep 18, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
325 X-L trimmer throttle doe not operate.
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Jul 11, 2010 | Husqvarna Forest & Garden 125c 17"...
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Husqvarna 365 order to install trigger, throttle catch and spring
Mar 23, 2009 | Husqvarna Garden
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Husqvarna 28cc Gas Line Trimmer Logo
71 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
