Question about Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD goes black after 2 or 3 seconds
I know that i need to replace the transistors(All 4 C507) .Where do I buy them? Do I need also the inverter transformers and the FET which drives the transistors.
  • TonyPru Mar 26, 2008
    Thanks
    I will try
    Novelist:
  • 138 Answers
Did you check CCFL lamps inside yet? If not, you should do that as well.
Posted on Mar 26, 2008
I have a Dell E173FP 17" monitor. The screen goes blank after a few seconds. When I press the on/off button to turn it back on, it comes back on for a few seconds and goes blank again.
Look for bad caps, shorted transistors, fuse, cold solder joints.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Sep 08, 2010 | Dell E173FP 17" LCD Monitor
Dell E173FP 17in flat LCD goes blank after about 10 seconds
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Replacement board:
Jul 11, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP LCD TFT 17" FLAT SCREEN Monitor
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement boards: www.lcdrepair.us
May 16, 2010 | Dell E173FP 17" LCD Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
Replacement bd: www.lcdreapir.us
May 14, 2010 | Dell E173FP 17" LCD Monitor
I have a problem with a Dell e173fp monitor. On power up, the power LED goes green and screen flashes on once very dimmly, then goes black.
Look for shorted out transistors (4) (c5706/5707) in the inverter circuits, this is common problem, post back what you see so we can guide you further.
Jan 31, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My monitor keeps shuttinhg off how do I fix it
Common problem for E172/173 are shorted out inverter transformers driver transistors (4) C5706/5707 in the inverter circuits.
Jan 28, 2010 | Dell E173FP 17" LCD Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
C5707 on 17" LCD DELL Monitor E173fp
You really need to replace all 4 as well as the 2 FU9024 chips. The solder is also bad in the inverter area especially around the 4 transformer legs. Check here for Instruction videos as well as parts and repair kits for that model.
May 17, 2008 | Dell E173FP 17" LCD Monitor
My solution: I searched many posts. My LCD also went black after 10 minutes or so, and green led was still on. Then i had to press power off and on to display again for minute or 2. I used reset function in its osd. And problem is gone! Yai!
Mar 27, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Tried to fix dell e172fpb
is the transistor the exact match?? checkif it is overheating??
let me know..
Nov 25, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
236 people viewed this question
Alun Cox
