Question about Sharp Heating & Cooling
External Compressor is working but unit inside not working. Sharp airconditioner. Filters cleaned.
  • 674 Answers
Check the circuit breakers for the indoor fan. If you have power to the fan then you might have a bad capacitor or bad fan motor. Make the power is off and see if the fan rotates freely by hand. You can use a multimeter to check the capacitor and the fan motor. If it is not any of these you can look at the fan relay to see if it is working.
Posted on Apr 30, 2010
We have a Carrier 25HBA unit and we've noticed a frost build up on the outside compressor, my husband turned the unit off and cleaned everything outside and up in the attic. It worked. No frost...
Hello
Frost or ice on the bigger outside copper line is a indicatin of possible low freon.Hopfully that is all it is.
It is also a possibility the compressor is getting ready to break,bad valves.
You will need a tech to come out and charge the system with freon.
Check your filter is clean and new first.
Sep 15, 2011 | Heating & Cooling
The unit does not blow cold air any more. Inside is sometimes hotter than outside. will be 85 inside but 80 outside. Have thoroughly cleaned filters, but no change. "comp" light is on
Hi, The compressor has gone bad and it will cost more to replace it then the unit is worth... buy another unit and buy anything BUT an Amcor unit... they are junk!!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Amcor AF9000E Portable Air Conditioner
Hi my name is Tom, The problem I have is my airconditioner runs and i've also cleaned filters, but it only blows nomal air...it dosen't seem to cool...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Check indoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3 degrees less than room temp.6.Check compressor is working with correct pressure.
Thanks. Helpful?
Jan 03, 2011 | Heating & Cooling
How to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Mar 24, 2010 | Heating & Cooling
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater...
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Dec 13, 2009 | Air Purifiers
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Compressor shuts down every 5 minutes or so. filters are clean
Shut down of compressor is triggered by thermostat, or overload protection inside the motor compressor.If there is an ice accumulation sensing/low temperature caused by clogged air flow, the system will shutdown. The air con must have cleaning, or the thermostat is defective.If the shut down is caused by overload protection, there might be a clog on the system tubing or the compressor need replacement.In rare cases the start up device (relay or PCT) may also cause that trouble.
Aug 31, 2009 | Sharp Heating & Cooling
Works dosent cool compressor still works maybe recharge
Make sure filter and inside and outside coils are clean
May 12, 2009 | Sharp Heating & Cooling
C6 error on airconditioner
6 - DC Peak Error
• Supplied power is not normal
• Comp Connector (CN-U,V,W) is disconnected or inserted to wrong
position
• Compressor is damaged (coil short) ? replace compressor
• Too much Refrigerant
• Defect in outdoor pcb assembly ? replace pcb assembly
Try turning power off to external unit, usually resets diagnostics and runs OK. If not PCB external unit likely culprit, replace!
Jul 31, 2008 | Heating & Cooling
Heating & Cooling Logo
108 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
