Question about Refrigerators
MY BJ 505 KEEPS KNOCKING OUT POWER AT HOME... AFTER I RESET THE TIMER BY TURNING THE DIAL ... IT RESETS AND POWER IS OK FOR A COUPLE OF HOURS UNTIL IT HAPPENS AGAIN
  • 4,066 Answers
Are you talking about resetting the defrost timer? I would check to see if the defrost heater is shorted out tripping the breaker when it goes into defrost mode.
Posted on Apr 30, 2010
How to set GE 15145 Box Timer, Mechanical Indoor?
http://waterheatertimer.org/GE-timers-and-manuals.html#15145
This timer is link a 24 hour clock. It rotates once each 24 hours.
Dial is marked with hours
The silver part of dial is for daylight hours 6 am 6 pm, and dark part of dial is for evening hours 6 pm to 6 am.
Put on-off trippers on dial at hours you want timer to operate.
Trippers should be marked with on and off
Below the dial... notice the words OFF ON and TIME are printed.
OFF and OFF correspond to the position of override lever. The override lever clicks back and forth between on and off as the trippers pass.
The word Time is printed inside a triangle that is pointed at the dial.
To set dial to current time, manually rotate dial until current time lines up with TIME.
So if it is 8:30 at your home, then rotate dial arouund until 8:30 lines up with TIME.
Sep 07, 2014 | Hardware & Accessories
I need help!!
unplug power for a couple of hours to reset it's memory.
Sep 14, 2008 | Durabrand W375-K Clock Radio
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
Dec 18, 2010 | Woods Outdoor Lighting Timer
How do I get it to start at dusk and run for 4 hours
You posted under Intermatic make HB51 timer.
To set for ON at dusk, and off 4 hours later, rotate dial to the number 4.
Timer turns on automatically at dusk because timer has photo eye.
Timer set to 4 hours will start countdown when timer turns ON > and 4 hours later timer will turn off.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on.
Feedback from lights will cause timer to reset the 4 hour countdown.
A car pulling in driveway can cause feedback.
If timer resets because of feedback, it begins 4 hour countdown again, so lights will not turn off until much later than planned, or not turn off until dusk.
Dec 18, 2010 | Intermatic Outdoor Timer/Photo Control...
HOW SET TIME ON AND OFF
You posted under intermatic 1020 timer
If this is not your timer, add a comment
How to set timer.
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
OFF trippers have to be at least 2 hours apart.
ON trippers have to be at least 2 hours apart
Minimum on-off function is one hour
Snap timer back together.
Rotate dial around until current time lines up with mark
Dial rotates with passing time.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning light switch on-off.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Dec 11, 2010 | Intermatic Timer E1020, Single pole/single...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Switching off of the iphone on its own.
Try these resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 19, 2009 | Apple iPhone Smartphone
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
