Question about Maytag CWE5800A Electric Double Oven
Heating The top oven works fine, the lower, larger oven won't preheat. You can set the temp and it may crawl slowly up to 150-175 but takes a half hour and won't heat up. It is had very limited use since new 2 years ago. It worked fine prior to setting the clean feature a few months ago.
  • tdellec May 29, 2008
    top oven works fine but the bottom oven won't heat up in bake or broil mode
    stays at 100C
  • mrvoy24 Jan 13, 2009
    I replaced the lower oven element and it only heats up to 175
    President:
  • Maytag Master
  • 2,651 Answers
I would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Posted on Mar 25, 2008
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Only preheats doesn't reach temp
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 09, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
It heats up..But it seems to take a really long time to preheat to the right temp
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Dec 27, 2010 | Ovens
My whirlpool oven was preheating for 45 min and only got to 230, but the broil setting works just fine. What is going on, is it the baking element?
heatman101
Nov 25, 2010 | Stoves Ovens
Oven temperature fluctuates.Oven heats to correct temp on preheat, but as the food cooks the temperature drops.
heatman101
Nov 17, 2010 | Frigidaire Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Maytag CWE5800A Electric Double Oven Logo
231 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
