Question about Garmin nuvi 765T GPS Receiver
Nuvi 765T won't load maps. Fires up, gets to the horozontal bar indicating that the maps are loading, but then goes dark and repeats. Held the on/off button for 8 seconds, but unit won't shut off. Didn't try a re-boot because everything I have loaded will get dumped. I have in plugged to my MAC via USB cable. Any thoughts. Thom
    President:
  • 1,851 Answers
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
Nuvi 765T doesn't recognize preprogramed SD card City Navigator Europe NT
Did you get this working? You may only need to access the menu and choose Maps and select deselect the current maps and select the Europe CNNT maps to get them to display.
If you need additional help - leave a comment.
Oct 08, 2011 | Garmin NUVI 765T 4.4 in. GPS Receiver
NUVI765T WON'T LOAD MAPS
It's likely that the maps are unselected. The other possibility is that the maps are locked. You can get the solution to both these problems at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you'll need. The details of selecting maps are at paragraph 5. If you need to unlock your maps you can start at paragraph 2.
Jun 07, 2011 | Garmin nuvi 765T GPS Receiver
Garmin just shows its loading maps and then screen goes blank and it repeats this even when I hold down the button for 10 seconds to reboot Why is it not turning on?
A Garmin Nuvi 1300 freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin 765 turns on and sais loading maps then
I've had this issue on my Nuvi 1300, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try that out and see if you have any better luck.
Apr 12, 2010 | Garmin nuvi 765T GPS Receiver
I tried to update my garmin. The screen doesnt move (or continue to download) I allowed for block ups.
You need to download and install the Garmin WebUpdater and Garmin Communicator Plugin both available from Garmin's website onto your computer. This allows updates to be installed directly to the 765T and provides the necessay USB drivers as well. The 765T must be connected to your computer when performing all updates or upgrades.
You may need to create a MyGarmin account and register your Nuvi 765T.
Resetting the 765T: with the unit off, press your thumb or finger in the lower right corner of the screen while turning the 765T on. This will clear all user data, base map software will remain intact. Connect 765T to computer and proceed with the Garmin WebUpdater.
Dec 22, 2009 | Garmin nuvi 765T GPS Receiver
My nuvi 765 will not turn on. Any solutions? How do you reset it? Vista will not even recognize the Garmin in the USB port. I'll assume that it's because it can't communicate to the OS. :) It just shows...
Resetting the Garmin Nuvi 765T: Press and hold your thumb or finger in the lower right hand corner of the screen while powering the unit on. This will erase all USER data, base and detailed maps will remain intact.
Connect your Garmin Nuvi 765T to your computer via USB.
Download Garmin's Communicator plugin and WebUpdater, both applications can be downloaded from their site. By doing so, this will load the necessary USB drivers to your computer, allowing the Garmin Nuvi to communicate and update firmware and software via the plugin and WebUpdater.
On Vista, the Nuvi 765T appears as Garmin Nuvi without the "T" as well, (a blue triangular icon also appears) it does not affect the ability to transfer files or explore the device in any way. If you load an SD card into the Nuvi 765T, it will appear as a removeable disk and assign it a drive letter, in my case H:
Dec 11, 2009 | Garmin nuvi 765T GPS Receiver
When I start my garmin nuvi 765t. it will try to start but just before finishing loading the maps it shuts down and keeps trying to start until I turn it off. also my computer does not recognize it when I...
Download the Garmin Communicator Plugin and Web Updater software from Garmin's website - both tools are free and will load the proper USB drivers for your 765T.
Ensure that the battery is fully charged via the battery strength icon, prior to aquiring satellites.
To reset the 765T: Hold finger or thumb on lower right hand corner of screen while powering the unit on from the off position. This will erase all user data.
Nov 16, 2009 | Garmin nuvi 765T GPS Receiver
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Aug 01, 2009 | Garmin nuvi 765T GPS Receiver
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
Loading of maps failed 'No detailed maps found that support routing. The nuvi cannot be used without them' message appears since I was in Slovakia.
I too had this problem with the Nuvi 260w. I tried loading the new 2010 map software two times with the same result. Those two times, I walked away from the computer and returned to find the installation window gone.
The third (and successful) time, I stayed at the computer the whole time. I didn't sit and watch the progress bar the whole time, but did other stuff on the computer, and returned to the status window every so often. It completed to 100% and at the end it indicated to click on the Finish button - this notice was not there the previous two times when I left it alone. I then unplugged the Nuvi and all was fine, the new map loaded, and all worked well.
So I'm thinking that the status window probably needs some type of activity on the computer to stay alive. I also noticed that the previous two times, the img file was smaller than the third time, so the installation to the GPS did not complete the first two times.
I hope this helps someone else with the same problem.
Jul 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 765T GPS Receiver Logo
959 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
