Question about OKI B4300 Led Printer
Oki b4300 with error 173
What you did to fix it....
  • Frank Howard
    Frank Howard Apr 12, 2008
    Got a throw away printer from work today - Oki Data B4350 - Started out with Change drum message but was able to access the maintenance menu and reset the drum counter. Got it to print out a few pages then started getting error 173 with an additional message of 2A14
  • 161 Answers
Because you drum is worn out, and resetting the counter only forces the unit to keep working with weared consumables. A new drum unit is quite expensive, but it lasts 20,000 pages so the cost per print is low.
Posted on May 28, 2008
2 Suggested Answers
SOURCE: Error code 173
Thanks, The cable was not plugged in right. Solved now.
Posted on Sep 22, 2007
Code 173 for oki c5500
Service call 172:Error & 173:Error
Both errors mean -
Abnormal temperature detected by fuser thermistor (high-temp or low temp.)
Does error reoccur?
YES -
Turn power ON again. Replace fuser unit.
Jan 19, 2011 | OKI C5500n Printer
OKI B4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Feb 22, 2010 | OKI B4350 Laser Printer
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Jan 27, 2009 | OKI C5100n Laser Printer
OKI B4300 Change paper
please keep the papers correctly aligned so that the sensors will recognize it...
good luck!!!!!!
dont forget to rate this
Aug 21, 2008 | OKI B4300 Led Printer
Oki B4300 LCD printer
Error 020 is a CU ROM Hash Check Error 1
It's most likely in need of circuit board replacement
If it's under warranty, contact the seller or
call 1-800-OKIDATA
Apr 05, 2008 | OKI B4300 Led Printer
Error code 173
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Sep 20, 2007 | OKI B4300 Led Printer
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
OKI B4300 Led Printer Logo
1,865 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
