I have a Lexmark 4690 printer which was scanning and sending e-mails for a long time and suddenly quit. It stated that the OCR was not installed so today I got out the disc and reinstalled it but just as it got to the end there was a file it could not find so I was not able to finish. I called my tech and he told me to go on the internet and download an updated version. I did this and did not find one especially for the X4690. I tried the 32bit for the XXXX listed but it will not connect with the printer. What do I do?
  • anderoak Apr 30, 2010
    I first noticed this problem around the 16th of April when I attempted to scan into an email and a message appeared on the screen telling me that the OCR was not installed from the printer driver. I had been using the scanner for almost a year up to this point and had no problems. So today I decided to remove the printer driver (Lexmark 3600-4600) and reinstall it. It was just about done when a message appeared on the monitor telling me that there was a bad file and so I could not finish. So I uninstalled it again. I called my tech and he told me to get Lexmark on the internet and download an updated driver. I did this this evening and could not find one specifically for my X4690 printer. I tried one 32bit one indicated for XXXX printers that printed, scanned, and copied. It downloaded but would not connect with my printer so i uninstalled it. All the other ones were drivers started with a Z before the numbers which were all in the 2300s. I need some specific instructions as to what driver I need to use.
  • 19,396 Answers
Hi.
The OCR is part of the Lexmark driver and software package.
Here driver download page:Driver for Microsoft Windows 2000, XP, Vista & Windows 7.
Click Download Now on the page linked above, then follow instructions on link below.
Here generic info on how to install a Lexmark printer when thedisk is misplaced.
Here support page for the C4690 all in one.
If that is not enough, you can contact Lexmark support via chat:
Live Chat
Please do not forget to leave feedback.
Posted on Apr 30, 2010
    President:
  • 2,923 Answers
Since the problem occur just today, and since you tried re-installing the driver but got the same problem, the thing that I could think of is for you to try performing system restore in your computer.
Restore your computer to the day you've last seen the Lexmark 4690 worked correctly.
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
How do set up my lexmark pro901 to scan to my pc so that I can email the scans
Make sure the Lexmark Pinnacle Pro901 printer driver is installed on your computer. If you have the install disc that came with your printer, just insert it to your computer hard driver and follow the instructions on your computer screen. You can also the download the printer driver from the Lexmark website at http://bit.ly/d3ftso. Select your operating system > download > execute the file. Again, just follow the instructions on your computer screen.
Note: The install disc contains the Lexmark OCR scan software necessary for scanning documents for editing and saving them as PDF files. The downloaded driver does not contain the OCR software.
To scan to your computer using the printer operator panel:
1. From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2. Touch USB-Connected Computer or the name of a network computer. The local or network computer is the destination that will receive the scan. Wait until the printer has finished downloading a list of the scan applications available on the selected computer.
3. Select an application (in your case your email), and then touch Accept.
4. Select the color, resolution quality and the original image size. If necessary, touch Accept each time you make a selection.
5. Press the start button to start scanning. The scan is complete when the application you selected in step 4 opens on the destination computer, and the scan appears within the application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1. Click Start.
2. Click All Programs or Programs, and then select the printer program folder from the list.
3. Select Printer Home.
4. Choose your printer from the printer drop-down list.
5. Click Email, and then select Photo, Document or PDF.
Note: You can select Document only if an OCR application is stored on your computer. Scanning starts and the scan progress dialog appears.
6. When the scan is finished, a new e-mail message is created with the scanned document automatically attached.
7. Compose your e-mail message. Note: If your e-mail program does not open automatically, then you can scan the document to the computer and then send it through e-mail as an attachment.
For Mac:
1. From the Finder desktop, double-click the printer program folder.
2. Double-click the printer Center to open the All-In-One Center.
3. From the "What is being scanned?" menu on the main screen, select a document type.
4. From the "How will the scanned image be used?" menu, choose To be viewed on monitor/web page.
5. From the "Send scanned image to" menu, choose an application.
6. Click Scan.
7. Retrieve the scanned image from the application, and then send it through e-mail as an attachment.
I hope this information has been helpful.
Sep 19, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Ocr i have lost my disc a long time back imy comp crashed and lost most of my comp. i need the ocr software to scan things on lexmark pro205
If you lost your installation disc to install the Lexmark OCR scan software, please contact Lexmark Technical Support Center to request for one.
Jul 22, 2011 | Lexmark Prospect Pro205 Wireless...
I can't scan on my lexmark printer model x5650. When I scan a document it gives me the message " Install the OCR from the OCR folder". I can't find the OCR folder in my computer. What should I do".
The Lexmark OCR scan software is available in the installation disk that came with the printer. You can explore the installation disk and look for the Abby setup application in the OCR folder (for Windows). For Mac OS, right-click on the Install icon and choose Show Package Contents. Open Contents folder > open Package folder and manually install the Abby Finereader application.
However, if you don't have the installation disk, contact Lexmark technical support. Thanks.
Sep 30, 2010 | Lexmark X5470 All-In-One InkJet Printer
Need ORC
Do you mean "OCR" - the Lexmark scan software? The Lexmark OCR scan software can only be installed using the installation cd that came with your Lexmark printer. It's not available for download. If you don't have it or you lost it, you can contact Lexmark Technical Support to request for that. They can send you one for free. Hope this helps.
Jun 25, 2010 | Lexmark X2600 InkJet Printer
Cannot scan document and save as PDF file
The only way you can install the Lexmark scan software (OCR) is by using the installation cd. It's not available for download on the internet. If your computer is not recognizing the installation cd, I suggest you contact Lexmark Technical Support to request for that. They can send you one for free. Hope this helps.
May 25, 2010 | Lexmark X3550 All-In-One Printer
Cannot scan document from printer to computer says no ocr found
You need to install the scan software(OCR software) in your computer. The scan software can only be installed using the installation cd. If you don't have it or you lost it, I suggest you contact Lexmark. They can send you one for free.
May 02, 2010 | Lexmark X2500 All-In-One Printer
I was given a Lexmark x7170 printer by a friend, but had no install disc. I downloaded the necessary driver for Windows XP and it has been working fine. I want to scan some documents into a word processor,...
Hello. The Lexmark OCR software can only be installed using the installation cd for your printer. The scan software is not available for download online since it's a big file. I would advise you to call Lexmark for assistance with the installation cd. They might send you one for free. Hope I can assist you more with this.
Mar 29, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
